10-08-07, 12:24
Coconut is offline
Join Date: Sep 2007 Location: San Jose, CA Posts: 27 | How to strip Ultima Paint Guard Plus? Ok, so yesterday was my first time applying Ultima Paint Guard Plus. I messed up pretty bad. Not only did I over apply it (streaking, unevenness), but I applied way too much pressure and ended up causing a bunch of fine scratches. What can strip PGP, maybe Dawn? | |
10-08-07, 12:28
| | I don't have much to add
SpoiledMan is offline
Join Date: Mar 2004 Location: Southern Cali Posts: 6,664 | Re: How to strip Ultima Paint Guard Plus? If you have the PPP then you should be able to go over the car with that to clean the paint and start fresh.
10-08-07, 04:50
| | "That ball wasn't low"
blkZ28Conv is offline
Join Date: Nov 2001 Location: VIR Road Course, Va Posts: 5,687 | Re: How to strip Ultima Paint Guard Plus? Isopropyl Alcohol or any paint cleaner (i.e. Prepsol). I would perform this task first prior to polishing out the surface marring since the application of PGP was so recent that it may gum-up your polishing pad prematurely.
PGP or any non-cleaning (abrasive containing) sealant should not mar your paint. You should check your applicator pad for defects (melted MF fibers or embedded dirt).
__________________ 04 Millennium Yellow Z06 (Zaino'd)
Zaino beta tester
10-08-07, 08:11
wannafbody is online now Join Date: Feb 2005 Posts: 5,660 | Re: How to strip Ultima Paint Guard Plus? 3m wax remover-Walmart carries it
2000 WS6 TA NBM
10-08-07, 08:14
Join Date: Mar 2004 Location: Southern Cali Posts: 6,664 | Re: How to strip Ultima Paint Guard Plus? Why such measures when a simple paint cleaner will take care of this??
10-08-07, 08:32
| | 1981 Camaro Z28
BigJimZ28 is online now Join Date: Mar 2006 Location: Levittown, Pa Posts: 2,901 | Re: How to strip Ultima Paint Guard Plus? you have scratches
so you are going to polish?
if so the polish will remove it | |
10-08-07, 09:49
Coconut is offline
Join Date: Sep 2007 Location: San Jose, CA Posts: 27 | Re: How to strip Ultima Paint Guard Plus? gotcha! I'll use PPP cleaner. Thanks! | |
10-09-07, 11:22
bert31 is offline
Join Date: Jul 2007 Location: Louisville, KY Posts: 1,105 | Re: How to strip Ultima Paint Guard Plus? Quote: |
if so the polish will remove it | Wouldn't a fresh coat of sealant gum up his pad? | |
10-09-07, 11:50
| | Administrator
DavidB is offline
Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,421 | Re: How to strip Ultima Paint Guard Plus? Quote: |
Originally Posted by bert31 Wouldn't a fresh coat of sealant gum up his pad? | That has not been a problem for me.
10-09-07, 11:51
csimian is offline
Join Date: Jun 2007 Location: Mill Creek, WA Posts: 59 | Re: How to strip Ultima Paint Guard Plus? How about sand blasting with leaf blowers? I'll let you guys know as my wife just told me that happened to my Mustang I applied 5 coats of PGP to  She said it didn't look that bad, but she's not meticulous like me  | |
10-09-07, 12:07
| | 1981 Camaro Z28
BigJimZ28 is online now Join Date: Mar 2006 Location: Levittown, Pa Posts: 2,901 | Re: How to strip Ultima Paint Guard Plus? Quote: |
Originally Posted by bert31 Wouldn't a fresh coat of sealant gum up his pad? | never had much of a problem with it
and I have a few pads and know how to wash them so it would not bother me if they did get gummed up | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 07:52. | | | |
