| Re: Should I use Ultima PGP on the windows and glossy plastic trim? Something in your process is causing the streaking unless you just got a bad bottle.
Make sure that you wipe away all residue from your prior step. I usually use the Detail Spray for this. You can also use an ONR QD mix for this. Apply it using less than you were using. That should do it. If it doesn't then let me know and I'll see if I can help. I've gathering a lot of experience with these products.
Black cars are fun! Yes, I *do* use grout sponges! |
