08-01-07, 07:19
| | Banned
WilliamHBonney is offline
Join Date: Mar 2007 Location: USA!!! Posts: 1,416 | Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove So I compounded and polished out a maroon Nissan Murano. I go to apply the Ultima PPP and I want to test the claim that it will remove swirls.
I applied via UDM at speed 6 with a orange LC CCS pad. Applied and let it sit for about 30 mins to haze on the passenger side while I dressed the tires I came back and it was glued to the paint. I couldn't wipe it off. I tried PBs SW and that wouldn't take it off.
So I took the applicator that came with it and put some on there and re-applied then it came off.
Ok it sat too long, noted.
I went to the other side, applied let haze for 3-5 mins and wiped off, well tried to. This stuff just wont budge. I then applied and didnt let it haze and wiped it off still wet, again, a total PITA to get off. The only thing that I have used that was worse in removing was Klasse SG.
What am I doing wrong?
One positive note, I was skeptical about the corrective abiliites of the product but it did take out some good size swirls, that was impressive. | |
08-01-07, 08:13
| | v Scottwax Wannabe v
Steelth is offline
Join Date: Feb 2007 Posts: 136 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove What did you think of the Paint Guard Plus?
Also I haven't gotten to use the PPP yet but reading this hopefully David will help out before Sunday or I might not be using it lol.
__________________ Owner
Proficient Auto Detailing LLC | |
08-01-07, 08:20
| | Banned
Join Date: Mar 2007 Location: USA!!! Posts: 1,416 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove I want to reserve my thoughts on it until I know if I did something wrong or not with it.
Im about 30 mins away from applying the PPP but I been glued to the TV with the bridge collapse just a few miles from us. | |
08-01-07, 09:22
gbackus is offline
Join Date: Feb 2004 Location: South Gate, CA Posts: 573 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove It's hard enough removing directly after application, I don't know why you'd want to wait 30 minutes | |
08-01-07, 09:26
| | I don't have much to add
SpoiledMan is offline
Join Date: Mar 2004 Location: Southern Cali Posts: 6,664 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove The instructions say to apply/remove one panel at a time. It also works perfect if you work it til it starts to clear out even in the sun. Also, a little goes a loooooong way.
08-01-07, 09:56
| | Banned
Join Date: Mar 2007 Location: USA!!! Posts: 1,416 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove Quote: |
Originally Posted by gbackus It's hard enough removing directly after application, I don't know why you'd want to wait 30 minutes | It said to allow to haze so that I figured that I would let it haze over while I worked around the car. WRONG!! | |
08-01-07, 09:58
| | Banned
Originally Posted by SpoiledMan The instructions say to apply/remove one panel at a time. It also works perfect if you work it til it starts to clear out even in the sun. Also, a little goes a loooooong way. | I guess I took the let it haze too far. But I did try on the other side applying and letting it haze for 2-5 minutes and that was still very difficult to remove. Then I tried the WOWO method and that also was difficult.
I have some PO 106FF coming tomorrow that I am going to use on Friday to polish out my Maxima and then I will give the UPPP another shot, this time with a white pad and see where we are at. | |
08-02-07, 08:34
| | Administrator
DavidB is offline
Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,421 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove If it's difficult to remove, you're using too much or not buffing long enough. Only a very fine film should remain. It should be a breze to wipe off or buff off with a bonnet.
08-02-07, 04:45
cdodkin is offline
Join Date: Jun 2006 Location: So Cal Posts: 164 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove What David said + get it off immediately with a MF towel, panel at a time - keep car in the shade at all times.
If it sticks at all - use speed detailing spray to assist in any removal - makes it easy.
But biggest tips are
Use Little
Polish till clear thin film
Panel at a time
Get it off before it dries
Use SD if any sticks
At least that's what I did after experimenting with my 1st application.
2nd was easier - and 3rd was a breeze.
Pro Motorsports Photographer in So Cal
08-02-07, 10:01
| | Banned
Join Date: Mar 2007 Location: USA!!! Posts: 1,416 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove Well I used it wrong then, I am doing another car tomorrow and will post the results of that detail as well as a review of the first use of Ultima PGP tomorrow. | |
08-02-07, 10:04
cdodkin is offline
Join Date: Jun 2006 Location: So Cal Posts: 164 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove Quote: |
Originally Posted by WilliamHBonney Well I used it wrong then, I am doing another car tomorrow and will post the results of that detail as well as a review of the first use of Ultima PGP tomorrow. | Best of luck - post results and let us know how you get on.
Bet you like the PGP
08-02-07, 10:10
| | Administrator
DavidB is offline
Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,421 | Re: Did I do something wrong?? Ultima Paint Prep Plus...What a PITA to remove Quote: |
Thanks! Your effort help me make the instructions better.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 04:54. | | | |
