| Polycharged KSG Tried the Polycharger H20 yesterday mixed with KSG on a friends 2006 black Dodge truck
Temp: Around 75deg
Process:
wash with Dawn
Clayed with Sonus Green
Polish via rotary (1200 RPMS) with Blackfire Ceramic Clear Finishing Polish
IPA 50/50 wipedown
Mixed 2oz of KSG with 3 doses of PCH20
Applied with MF Applicator spritzed with Acrylic Spritz
Application:
About like regular KSG.
Drying:
Allowed it to "dry" for 30 minutes before removing. It looked completely hazed in about 15 minutes or so.
Removal:
This is where it got wierd. The hazed product came off pretty easily even in spots where it was applied a little to heavy. In the garage where I was working it seemed to be doing fine. I then pulled it out into the sun and found that the surface looked streaked. It's kind of hard to explain but it was like the product had never dried completely. You could wipe and wipe on one area and all it would do is change the direction of the "streaks". It had a a somewhat oily look to it. We let it set for another hour and tried to remove it with the same results, then we tried some QD with no luck either. I could only see the "streaks" when the sun was at the correct angle but they were there for sure.
Appearance:
Looking at the truck in the shade it was beautiful, very very wet looking without the classic KSG candy shell look. In the sun it also looked great until you got the sun's reflection at just the right angle then those dang streaks would show up.
Slickness:
Slicker than straight KSG by far, I'd say it easily puts it up there with non-boosted FMJ or ZFX'd Zaino.
Overall I'd say the main positive for the boosted KSG is improved slickness. The negative of course was the streaking. I'll report back after the first wash to see if the streaks disappear which I believe they will. This will also be a good test for durability as the truck isn't garaged.
