Go Back   Autopia.org > SPONSOR FORUMS > Premium Finish Care
Old 06-02-08, 05:14   #1 (permalink)
bumoftheday is offline
bumoftheday is on a distinguished road
Can UPPP be used as a finishing polish?
I'm going to be using UPGP on a car coming up shortly and would like to put down UPPP. I will be using SIP and have 106ff. Should I skip the 106ff and just use UPPP via DA to finish?
Old 06-02-08, 06:15   #2 (permalink)
KnuckleBuckett
KnuckleBuckett's Avatar
KnuckleBuckett is offline
KnuckleBuckett is on a distinguished road
Post Re: Can UPPP be used as a finishing polish?
If you are going to use UPGP. I would always recommend using the UPPP.
For my LS430 I used the following process.
Yes.
I know it was overkill. I like my car.
Pre-soak with P21S.
Wash with Ultima car wash.
Pinnacle Ultra Poly Clay with ONR mixed as lube.
Heavy pads (purple wool or yellow foam) as required with either Menz Power Gloss or SIP. Hint if you are using PG, try a little 106ff or Ultrafina to help with the dusting.
Orange pad with Menz SIP.
White pad with Ultrafina (stuff ROCKS) rather than Menz 106ff.
Blue pad with Menz PO85.
Red pad UPPP.
Kept pads moist with Ultima detail spray.
Used thick heavy clean MFs and detail spray to wipe off polish stages.
Finished with...
UPGP x 2
DWG x 2
UPGP x 2 (might add 2 more)
Tires with Ultima Exterior x 2 (let each coat dry thoroughly) then 2 coats of Blackfire
Glass... clayed with ONR as above, cleaned 2x with Surf City, sealed with PGP Aquapel.
Engine bay and all seals same as wheels minus the BF.
Leather Lexus leather cleaner and kit.
Interior trim 303.
Carpet and interior glass (yet to finish).
All pads are 5.5" Smart Pads.
Old 06-04-08, 04:45   #3 (permalink)
Shuskan3's Avatar
Shuskan3 is offline
Shuskan3 is on a distinguished road
Depending on how hard or soft the paint is you should be able to use UPPP after SIP, but if you are still seeing hazing after UPPP use 106FF first.
Edge 2K Finishing Wool Part Number... SuperBee364 Car Detailing Product Discussion 12 05-20-08 11:22
Curious - Your Rotary Pad Size, Type...? charlesaferg Machine Polishing 25 05-04-08 10:08
Optimum as a FINISHING polish? (i.e. WHITE LC CCS PAD?) m4gician Car Detailing 12 12-24-07 03:25
AIO as a finishing polish? NHBFAN Car Detailing 1 04-05-04 06:26
24 hour wait between coats of Zaino? 50th yr Car Detailing 23 11-18-02 03:35
