10-09-07, 07:46
Logan2224 is offline
Join Date: May 2006 Posts: 42 | differences in clay Just a quick question. What are the differences between the gray colored Sonus clay, and the green colored clay?
Thanks | |
10-09-07, 09:14
| | Administrator
DavidB is offline
Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,421 | Re: differences in clay The grey Sonus BLOCK clay is a medium duty clay, whereas the green Sonus SFX Ultra-Fine is the finest clay made.
We have decided to stop making Sonus BLOCK because sales of the Sonus SFX Ultra-Fine are 5:1 over BLOCK. The big difference is that Sonus SFX Ultra-Fine will not remove paint overspray or very heavy oxidation. Rather than have the confusion of two clay products, we decided to simply drop BLOCK and recommend a body shop grade clay when it is necessary.
Sonus BLOCK is on clearance for $12.95 for two 100 gram bars with a plastic container: Car Detailing Clay & Overspray Remover - Sonus Block Detailing Clay Bar
We have 25-30 units remaining.
10-09-07, 11:07
bert31 is offline
Join Date: Jul 2007 Location: Louisville, KY Posts: 1,103 | Re: differences in clay Quote: |
Originally Posted by DavidB The grey Sonus BLOCK clay is a medium duty clay, whereas the green Sonus SFX Ultra-Fine is the finest clay made.
We have 25-30 units remaining. | Is Elastrofoam more comparable to the Block or SFX Ultra-Fine? Or is the difference between Elastrofoam and clay too great to make a comparison?
On a side not, I have always liked the Block Clay, I will miss it.
Reason: Typo
10-15-07, 09:24
| | "The Car Girl"
Lynn Phillips is offline
Join Date: Mar 2003 Location: Sunny So Cal Posts: 613 | Re: differences in clay Quote: |
Originally Posted by bert31 Is Elastrofoam more comparable to the Block or SFX Ultra-Fine? Or is the difference between Elastrofoam and clay too great to make a comparison?
On a side not, I have always liked the Block Clay, I will miss it. | The Ultima Elastrofoam is middle of the road, it is about dead center as far as aggressiveness between the Sonus Block and Sonus SFX Ultra Fine clay.
Lynn
__________________ Lynn Phillips
Customer Svc & Product Tech Support Autopia Car Care
Direct Line: (858) 605-0296
10% Autopia Member Coupon Code: AUTOPIA | |
04-01-08, 08:43
| | Calm like a Bomb
EisenHulk is offline
Join Date: Mar 2008 Location: Lexington, KY Posts: 1,004 | Re: differences in clay I'm new so, I'm just now seeing that the Block clay was dropped. David mentioned a body shop grade clay, when something stronger is needed. Could you help a newbie out and recommend a good "body shop" grade clay.
Thanks. | |
04-01-08, 08:54
bert31 is offline
Originally Posted by EisenHulk I'm new so, I'm just now seeing that the Block clay was dropped. David mentioned a body shop grade clay, when something stronger is needed. Could you help a newbie out and recommend a good "body shop" grade clay.
Thanks. | Quick Detailers & Clay Bars
Danase Medium Grade Detailing Clay (200g) should be just what you are looking for. | |
04-01-08, 09:02
| | Calm like a Bomb
Join Date: Mar 2008 Location: Lexington, KY Posts: 1,004 | Re: differences in clay Thanks, Bert.
I'll get some of that ordered today. | |
04-01-08, 09:10
| | Administrator
DavidB is offline
Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,421 | Re: differences in clay Quote:
Originally Posted by bert31 | You do realize that The Perfect Shine pays for this forum area as a PRIVATE support forum, right???
04-01-08, 09:16
| | "The Car Girl"
Thanks. | It's easy to randomly recommend a clay but I find it best to find out a little more about what you are working on first as you always want to use the least aggressive first.
If you could give me a little more information regarding your surface and the shape it is in as well as the severity of the contamination, I would be more than happy to help recommend the appropriate clay for your situation.
Lynn
04-01-08, 10:13
bert31 is offline
Originally Posted by DavidB You do realize that The Perfect Shine pays for this forum area as a PRIVATE support forum, right???  | Sorry.
(10 char minimum) | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 01:58. | | | |
