Old 08-29-07, 11:47   #1 (permalink)
kchau is offline
kchau is on a distinguished road
4 inch pads
will the udm work with the equipment seen here?
New, 4 inch, CCS Technology, Spot Repair Pads
Old 08-30-07, 12:01   #2 (permalink)
BigAl3 is offline
Re: 4 inch pads
yes, just make sure to get the 3 1/2 backing plate to accommodate them..
also... if you're looking for a place to buy the backing plate (amongst others great items) patrick over at exceldetail.com has them, and i've been using mine for a while with no problems...
Old 08-30-07, 05:37   #3 (permalink)
WOOL4LIFE
Coupe is offline
Coupe is an unknown quantity at this point
Re: 4 inch pads
Dont know why people get confused about this.
What works on the PC will work on the UDM, they are the same machine, one is just on steroids.
WOOL rules FOAM drools
CarDomain.com
Old 08-30-07, 06:00   #4 (permalink)
rwisejr's Avatar
rwisejr is offline
rwisejr is on a distinguished road
Re: 4 inch pads
I think the main reason is from the problem that the UDM currently has with the edge system.Until the new counter weight is available . I think i does have some issues with the 6 inch backing plates as well.But David can confirm this if I'm correct.But the smaller 5 inch and below should not have any issues that I'm aware of.
Ron
Club FLEX Member, Club Rotory Member Club Systemone Member
Old 08-30-07, 06:11   #5 (permalink)
WOOL4LIFE
Coupe is offline
Re: 4 inch pads
The PC has problems with the edge system also, it kills adapters quick, fast and in a hurry.
CarDomain.com
Old 08-30-07, 06:16   #6 (permalink)
DuraGloss User
AL-53's Avatar
AL-53 is offline
AL-53 is on a distinguished road
Re: 4 inch pads
I agree with Coupe...I used the PC with the edge pads and I was not impressed....seems they bog the machine and the adapter gets hot ..seems the random orbit sorta grinds the balls down and they start to fall out....Edge on a rotary works good..but PC is another story..some have good luck with it..I did not....
AL
2004 Ford Ranger FXII
Bright Red
My Pitbull rides shotgun
Old 08-30-07, 06:20   #7 (permalink)
WOOL4LIFE
Coupe is offline
Re: 4 inch pads
The edge2k system is all i use on my rotary, will never go back to the traditional hook and loop system.
CarDomain.com
Old 08-30-07, 03:19   #8 (permalink)
kchau is offline
Re: 4 inch pads
so will the reduced weight of the 3.5" backing plate work well on the udm? or will it be out of balance?
Old 08-30-07, 03:25   #9 (permalink)
DuraGloss User
AL-53's Avatar
AL-53 is offline
Re: 4 inch pads
it will work fine...DavidB did a demo on scratch removal with a 4" pad and he said it was fine...
AL
Bright Red
Old 08-30-07, 04:10   #10 (permalink)
Late bloomer
Bunky's Avatar
Bunky is offline
Bunky is on a distinguished road
Send a message via AIM to Bunky Send a message via Yahoo to Bunky
Re: 4 inch pads
I have a UDM and used the 4-in pads with the smaller backing plate (2.75) without any vibration issues. I believe the counterweight issue is related to heavier pad/plate combo's so smaller (less weight) is better.
Al
Old 08-30-07, 04:40   #11 (permalink)
Super Moderator
JDookie's Avatar
JDookie is offline
JDookie is on a distinguished road
Re: 4 inch pads
The 4" pads work beautifully on the UDM.
Old 08-30-07, 04:49   #12 (permalink)
No prep, no pride!
a.k.a. Patrick's Avatar
a.k.a. Patrick is offline
Re: 4 inch pads
Woah! Consider a 3.5" BP for those pads, you'll find better results with less edge stress, equaling better pad durability....
I sue the 4" pad setup with the 3.5 BP, and have had great results. I would like to move up to a 5" pad, 4.5 BP though.
You-Dee-M'er...
New Cyclo Dual Precision Pads Anthony Orosco Machine Polishing 27 02-21-07 05:22
FS: Lake Country7.5 inch advanced foam polishing pads GDA4 Good Deals 1 11-08-06 08:47
Best pads for rotary that don't splatter RAG Detailing Product Discussion 1 12-18-05 07:49
Looking for 1Z products and 7.5 inch pads... OneQuickGT1 Car Detailing 2 03-11-04 02:10
8 inch Meguiar's Pads Marty Car Detailing 2 12-27-02 12:06
