Go Back   Autopia.org > SPONSOR FORUMS > The Perfect Shine
Old 09-09-07, 06:36   #13 (permalink)
Patman's Avatar
Patman is offline
Patman is on a distinguished road
Re: Stock (basic) White UDM pad?
Originally Posted by m4gician
eshine.ca of course you already know that because that's how you bought your UDM
But eshine doesn't sell that pad though, if you look on their site it only shows the 4", 6.5 and 7.5 LC pads, but it doesn't have any 6" pads like the one that comes with the UDM.
Old 09-11-07, 07:30   #14 (permalink)
MrAP is offline
MrAP is on a distinguished road
How about the "Scratchbuster" at Ultimate Detailing Machine DAS Foam Pads
Old 09-12-07, 05:12   #15 (permalink)
klumzypinoy's Avatar
klumzypinoy is offline
klumzypinoy is on a distinguished road
I got the scratch buster pad with the UDM. I'm glad I got it, it works really nice and there's a small safe zone for the backing plate. I didn't know that there's two different pads that come with the UDM.
Old 10-10-07, 03:12   #16 (permalink)
Lurker Extraordinaire
Sherri Zann's Avatar
Sherri Zann is offline
Sherri Zann is on a distinguished road
Is the white pad that comes with the UDM (no CCS style indents) the same foam as LC white pads?
Is this a good pad to use to with PGP, or should I use my UDM Green pad instead?
Is it possible to be a moderate Autopian? Not in my own experience.
Old 10-10-07, 03:37   #17 (permalink)
Late bloomer
Bunky's Avatar
Bunky is offline
Bunky is on a distinguished road
Send a message via AIM to Bunky Send a message via Yahoo to Bunky
They are both polishing pads but they do not appear the same foam type. I have only used the CCS type with my UDM but I do have the white pad that came with my UDM.
Al
Old 10-11-07, 09:37   #18 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
The stock UDM pad (white 6.5" pad) is a common REGICELL 60 foam. This pad is good for light polishing and pre-wax cleaning tasks. It does not have enough density or cut to bbe useful as a swirl or defect removal pad. It can also be used with cleaner waxes, such as Klasse AIO or Meguiar's ColorX.
Replacements are available from Foam Polishing Pads
db
Autopia.org Mayor At-Large
Old 10-11-07, 09:44   #19 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
The ScratchBuster pad is a pre-polymer foam with a density and structure that is nearly the same as the Swisstex orange foam. It has a slightly large pore, allowing it to work very well with light cut compounds and agressive swirl removers.
The pad is cut to a smaller diameter (5.75") to make it work even faster when used at higher speeds with the UDM.
When used with a quality polish to remove defects, this pad leaves very little (if any) hazing.
How I made my own backing plate from the stock PC Pad randallhb Car Detailing Product Discussion 8 05-27-07 10:18
AIO Which Pad White or Grey? SHICKS Machine Polishing 8 03-20-05 07:38
Machine Buffing DavidB Car Detailing 13 06-12-03 04:19
CMA white pad fell apart and it was smoking.... joed1228 Car Detailing 7 05-10-02 08:14
Should the 3M SMR be applied using a white or yellow pad ? Irvin Car Detailing 7 12-28-01 09:00
