Originally Posted by Ruttrow I was looking at the 5-1/4 pads from Lake County. Before I spend MORE money does anyone know why if that is indeed the case why most resellers package with 6" pads? If what cgage is saying is correct why not supply with what appears to be a less expensive pad. Just because of size that is. Thanks. |
Vibration is a function of balance and weight. Some pads that are the same weight and size will feel differently depending on how the pad is constructed. I notice this on both the UDM and the PC.
If you looked at the UDM DAS pad line you will notice that the pads are different size (thickness and diameter) based on function. In general, the more agressive the pad, the smaller the size.
The cost of a pad has more to do with material and labor than size. A straight cut disk has fewer steps than a pad with rounded corners, etc. The method of Velcro attachment is also a big factor in cost.
db
