Originally Posted by Jesstzn First off it looks great .. didn't get a chance to use it as it showed up right at the end of a detail..
#1 Is the shaft where the backing plate bolts into supposed to move in and out? Mine moves out 1/4" or so.
#2 How is the on off switch going to hold up? .. My PC is pretty marked up in that area as I lay it on its back on the pavement a lot. |
#1 -- NO, it should not move at all. The center idle shaft has two pilot bearings. Between the two pilot bearings there should be a spacer that is just about .25" thick. I suspect that you have a counter weight system that was not assembled properly (missing the spacer). It's not possible to put just the spacer in, as the bearings are pressed onto the shaft. We will have to send you a new polisher or a new counter balance. If you want to verify what I'm saying, simply remove the three screws holding the counter balance/eccentric on and have a look.
#2 -- The on/off switch itself is not an issue. The slide mechanism needs resistance to prevent accidental on/off. The modification we will send out includes a small felt pad to apply to the slide to provide the resistance needed.
db
