06-26-07, 09:10
eShine is offline
Join Date: Apr 2004 Location: Canada eh? Posts: 383 | LC CCS Pads and UDM David, we are arranging to order the UDM’s for eShine. We are also currently switching over to Lake Country 6.5” CCS pads, are there any reported problems using these pads or can they take the extra nuts of the UDM?
__________________ Chris Pace,
eShine Canada | |
06-26-07, 10:43
WhosRich is offline
Join Date: Jun 2007 Location: New York Posts: 56 | Re: LC CCS Pads and UDM ^+1.. I'd also like to know this as well since i just ordered some CCS pads for my UDM. i hope i didnt waste my money..  | |
06-26-07, 11:03
| | I don't have much to add
SpoiledMan is offline
Join Date: Mar 2004 Location: Southern Cali Posts: 6,664 | Re: LC CCS Pads and UDM No problems for me. I'm using the 5" pads with a 4.75" BP. They heat up pretty good in some cases but have no problem holding up.
06-26-07, 11:23
eShine is offline
Join Date: Apr 2004 Location: Canada eh? Posts: 383 | Re: LC CCS Pads and UDM Quote: |
Originally Posted by SpoiledMan No problems for me. I'm using the 5" pads with a 4.75" BP. They heat up pretty good in some cases but have no problem holding up. | How does that 4.75" plate work on 6.5" pads I wonder. I have a large order of CCS pads in the works and want to make sure I have pads that work for both the PC and UDM.
eShine Canada | |
06-27-07, 07:21
| | Empty My Wallet
crew219 is offline
Join Date: Jun 2005 Location: ITH, NY Posts: 205 | Re: LC CCS Pads and UDM I believe the only requirement David mentioned was that the pads should use PUR glue. I'm not 100% sure if there are differences between the glue used on CCS pads with the white and black velcro, but the pads with the black velcro backing have proven to be much more durable in the long run.
Dave | |
06-27-07, 09:04
| | Administrator
DavidB is offline
Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,421 | Re: LC CCS Pads and UDM I'm discovering some interesting facts regarding the UDM and pads:
1. The UDM has a lot more torque than the PC so it can be run at a slower speed to accomplish the same tasks. You really only need to "crank it up!" when cutting off heavy swirls and scratches. As as a result, I'm not experiencing as much Velcro damage.
2. The torque combind with added pressure allow the pad to heat up faster to better work the polish. That means you can use a more agressive polish with a less agressive pad and get a better final finish (as long as the polish breaks down properly)
3. A smaller backing plate is working well (for me) because the pad gets warm and stays warm... whereas with the PC I felt I needed a larger backing plate to lay down the power and get the pad up to temperature.
I don't see any issue with the CCS pads on the UDM when used with a 5" backing plate.
06-27-07, 11:31
lecchilo is offline
Join Date: Jun 2005 Location: Chicago USA Posts: 910 | Re: LC CCS Pads and UDM Don't buy LC pads from CMA, that's all the advice I can give you... UDM will fling them across the room in a matter of minutes.
I can't wait to get my UDM... David do you have a spare laying around somewhere that needs a good home ?
-Ivan
LUSTR Auto Detailing
06-27-07, 12:35
| | Administrator
DavidB is offline
Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,421 | Re: LC CCS Pads and UDM Quote: |
Originally Posted by lecchilo Don't buy LC pads from CMA, that's all the advice I can give you... UDM will fling them across the room in a matter of minutes. | Have experienced and issue with LC pads we're not aware of?
06-27-07, 12:55
rwisejr is offline
Join Date: Feb 2007 Location: LI NY Posts: 403 | Re: LC CCS Pads and UDM David i think he is relating to an issue with velcro backing pads seperating from the one purchased through CMA
Ron
Club FLEX Member, Club Rotary Member Club Systemone Member | |
06-27-07, 02:10
| | Administrator
DavidB is offline
Originally Posted by rwisejr David i think he is relating to an issue with velcro backing pads seperating from the one purchased through CMA | Okay... but that sounds like an LCM issue, not a CMA issue. I have no doubt that CMA handles product defect issues with complete professionalism.
06-27-07, 02:42
Danase is offline
Join Date: Jan 2006 Location: Michigan Posts: 2,946 | Re: LC CCS Pads and UDM Quote: |
Originally Posted by DavidB Okay... but that sounds like an LCM issue, not a CMA issue. I have no doubt that CMA handles product defect issues with complete professionalism. | I think he said CMA because I think CMA is the only place carrying the pads with the blue edging that seemed to have the bad rap.
06-27-07, 02:45
| | Administrator
DavidB is offline
Originally Posted by Danase I think he said CMA because I think CMA is the only place carrying the pads with the blue edging that seemed to have the bad rap. | Ah... my bad! I'll just get back to what I was doing and keep my mouth shut
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 12:01. | | | |
