05-07-07, 08:58
Bbasso is offline
Join Date: Apr 2004 Location: South Carolina Posts: 220 | I had trouble with the sonus pads, how about you? I was buffing out a car yesterday and the velcro part that is glued to the pad just came off and I almost put the buffer's backing plate thru the door. Has anyone else had this problem?
Is there a fix for this, any special glue I should use to stick it back on or should I contact the company?
And this is not the only pad with this problem, the other two are starting to peal off also
Rob.
itrca.com
05-07-07, 09:30
| | WOOL4LIFE
Coupe is offline
Join Date: Apr 2006 Location: Grand Rapids Mi Posts: 1,971 | Re: I had trouble with the sonus pads, how about you? Ive had 2 DAS oranges seperate on me. All the DAS polishing and finishing pads are still holding strong and ive beaten the crap out of them. | |
05-07-07, 11:56
Bbasso is offline
Join Date: Apr 2004 Location: South Carolina Posts: 220 | Re: I had trouble with the sonus pads, how about you? Well I called and left a message about this, I hope they get back to me quickly... I have four upcoming jobs that I need these pads for.
Rob.
itrca.com
05-07-07, 03:56
Bbasso is offline
Join Date: Apr 2004 Location: South Carolina Posts: 220 | Re: I had trouble with the sonus pads, how about you? Why was this thread moved and why wasn't I told?
It fit the product discussion, no?
I would have kept this in PM but I have no clue who did this.
Rob.
itrca.com
05-07-07, 04:19
| | Time's a-wastin',speedy!
TortoiseAWD is offline
Join Date: Jun 2001 Location: Omaha, NE Posts: 3,343 | Re: I had trouble with the sonus pads, how about you? Quote: |
I would have kept this in PM but I have no clue who did this. | I moved to the Autopia Car Care forum so that the vendor (ACC) can address your problem with the Sonus pads. The post would fit in both forums, but now that the thread is here, you can bet that Lynn Phillips will be contacting you shortly to take care of it.
We (moderators) don't typically send a PM for a moved thread. Sorry for any inconvenience or confusion; I was just trying to help out by putting the thread where the vendor would see it and respond.
Tort
(moderator)
"I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents." -- James Madison
05-07-07, 06:15
| | "The Car Girl"
Lynn Phillips is offline
Join Date: Mar 2003 Location: Sunny So Cal Posts: 612 | Re: I had trouble with the Sonus pads, how about you? Hi Rob,
Don't worry, I have taken care of you and your replacement pads will ship first thing in the morning via Priority and we are truly sorry you have had trouble.
Lynn
PS Thanks, TortoiseAWD for putting the post where I could find it!
__________________ Lynn Phillips
Customer Svc & Product Tech Support Autopia Car Care
Direct Line: (858) 605-0296
10% Autopia Member Coupon Code: AUTOPIA | |
05-08-07, 09:05
Bbasso is offline
Join Date: Apr 2004 Location: South Carolina Posts: 220 | Re: I had trouble with the sonus pads, how about you? thank you so much for the very quick help, I`m happy with the level of customer service
Rob.
itrca.com
05-08-07, 02:15
95legend is offline
Join Date: Nov 2004 Posts: 53 | Re: I had trouble with the sonus pads, how about you? I've also had problem with the Sonus pad once. Autopia was quick to replace it. I would do service with them again for this reason  | |
05-12-07, 08:19
Sylverlee is offline
Join Date: Apr 2004 Location: Irvine, Ca Posts: 13 | Re: I had trouble with the sonus pads, how about you? Same with my clay. Replaced promptly~ | |
05-16-07, 01:47
bjz is offline
Join Date: Mar 2007 Posts: 1 | Re: I had trouble with the sonus pads, how about you? Same thing happened the first day of useage on my green pad. They replaced it promptly. Just have to let them know. Excellent customer service. I didn't even have to send the old one back. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 03:30. | | | |
