The very first thing... let's get you a new backing plate. It is possible the backing plate itself had a defect and was causing virbration. We get about 10-15 out of 1,000 failures. It looks like you may have one of them. Please email
support@theperfectshine.com with your order number and we will Priority a replacement to you today!
Another issue we have seen is that the PC 7424 is simply a bad unit. We could try to change out the weight, but in my experience this rarely works.
Try the new backing plate. Run the machine at 5.5 as you highest speed for most applications. If you compress the pad more than 50-60%, you're applying too much pressure.
If you still get excessive vibration, we'll replace your PC.
DavidB
