Originally Posted by Accumulator DavidB- Hope this isn't a threadjack, but any tips on using the Motorkote? |
Not a threadjack at all... good discussion.
I documented how I use this product in
this article. Basically, the engine compartment needs to be clean and dry. If the engine compartment is slightly warm, I find that it works better (warmed to 110-120 degrees is great).
I do mask off. Laying towels on the fenders is enough. Wiping off overspray is fine. The "no wipe" comment refers to the parts being coated. If you create puddles, the puddles should be soaked up using a small sponge.
This product has been around for a long time. Meguiar's sold it under the name EngineKote. They dropped it when they brought chemical manufacturing in-house. So, anyone who has used EngineKote in the past knows exactly how this product works.
I use this product a lot on the engine and in wheel wells. It is very tollerant to normal wear and easily last 6 months on an engine the is well protected with a splash pan.
I'm in the process of testing it will Polycharger, which seems to make it apply more evenly and dry faster. We'll see if it lasts longer.
db
