Originally Posted by DavidB Chris,
I'm going to have to break out a bottle of NXT and see if I can duplicate the same results applying it after SBP. How long did you wait to apply NXT after using SBP?
db |
Only 10 mins - I moved straight on to the NXT application with the PC on 3.5, and the blue pad.
I probably used too much NXT - although I've really cut back since using it with the PC.
Agree with Justin, you only need the thinnest of layers.
Just odd how I got spots where it stuck....
Maybe I did overload the MF bonnet - any tips - or do I just need to keep swapping it out when it gets loaded with wax?
Chris.
