Go Back   Autopia.org > SPONSOR FORUMS > The Perfect Shine
Old 06-11-06, 02:07   #1 (permalink)
grinchydizz is offline
grinchydizz is on a distinguished road
how to get leather cleaner off plastic???
any tips on how to get leather conditioner off of an instrument panel? It accidently splattered onto it, and now there are spots that I cant clean off of it. I tried windex, and plain old water, its not working.
Old 06-11-06, 02:10   #2 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
Did the conditioner dry on the panel?
I have a large GPS panel on my SUV and have also splattered conditioner on it but it cleans off the glass cleaner.
Autopia.org Mayor At-Large
Old 06-11-06, 09:02   #3 (permalink)
yep, it dried, in the hot AZ sun! I did try some glass cleaner, but didnt work. My hubby said I will probably need to replace the plastic, I noticed I got it on the back window as well. I should have been more careful!
Old 06-11-06, 09:20   #4 (permalink)
ronmart's Avatar
ronmart is offline
ronmart is on a distinguished road
Put Dawn on a wet sponge (squeeze out the excess water first) and wipe down. It should come off quite easily, and of course you'll need to use a clean wet sponge to remove the soap. Follow up with your window cleaner.
Old 06-11-06, 09:26   #5 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
If the glass cleaner did not remove it, there's a good chance Dawn won't touch it either, but it is worth a try.
If Dawn won't remove it, my next suggestion is Plexus. I don't think you'll have to replace the plastic, but if Plexus does not work the, next remedy is Meguiar's PlastX (or another plastic polish), which will make the lens sightly glossy.
db
Old 06-13-06, 09:31   #6 (permalink)
hi, thanks for all the advice. Where do I get these products? I will try anything at this point too!
Old 06-13-06, 10:55   #7 (permalink)
ronmart's Avatar
ronmart is offline
Dawn - at your local grocery store, target, etc... he he
The other stuff can be found at http://autopia-carcare.com/
Old 06-14-06, 02:34   #8 (permalink)
buzzb is offline
buzzb is on a distinguished road
You should also be able to find Meguiar's PlastX at Advance Auto.
http://www.autopia-carcare.com/meg-g-12310.html
Old 06-14-06, 09:09   #9 (permalink)
thanks for the info. While Im at it, I might as well ask. On my daughters 1995 Dodge Stealth, it has a "haze" on her windshield, I have no idea what it is. It causes a glare if the sun hits it just right. And, of course with my luck, I cant get it clean. Ever heard of that?
Old 06-15-06, 07:34   #10 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
Have you tried a glass polish yet? If the glass is damaged the polish will not repair the damage, but it will remove stains and grunge.
db
Old 06-15-06, 07:56   #11 (permalink)
ronmart's Avatar
ronmart is offline
If you have an orbital, then polish the glass using an orange pad and something like Sonus or Griots Glass Polish. NOTE: Make sure there is no protective film out the outside of your glass before you do this (there should be a label on the glass or you can ask a local glass shop).
I have only seen hazes on the outside from chemicals like RainX, or something spilled on the road (like oil). Usually hazes are on the inside, so make sure you clean well on the inside with something like Invisible Glass first. I spent a few hours trying to get a mark off my exterior glass one time, only to discover the mark was on the inside and it wiped off easily!!!! DOH!!!!!
