January 31, 2006, San Diego, California – Autopia Car Care is pleased to announce a new breakthrough in paint care technology… Sonus SwirlBuster™.
Sonus has developed a revolutionary new system, SwirlBuster™, which quickly and easily eradicates swirl marks, holograms, and other fine surface marring from modern clearcoat finishes. In recent years, swirl mark removal from modern clearcoat finishes required the use of a rotary polisher, harsh abrasives, or hours of polishing using a dual-action (orbital) polisher. This is due to the hardness of new clearcoat finishes.
Sonus product developers solved the swirl removal problem in two ways, making swirl mark removal safe and easy using a dual-action machine, like the
Porter Cable 7424 car polisher.
The first breakthrough is our Sonus SwirlBuster™ Foam Polishing Pad. The new pad fits all dual-action and rotary polishers with a 5” to 6” Velcro backing plate. The new pad use the same Swisstex “FOAMGLAZE” foam found in our DAS Orange Pad, only much thicker. In fact, the SwirlBuster Pad is 30% thicker! The additional thickness allows more pressure to be applied to the pad without “bottoming out” and creating dangerous hot spots.
The Sonus SwirlBuster™ Foam Polishing Pad also has a fresh new face. We cut grooves (“polish pockets”) into the face of the pad that allow the pad to be loaded with polish. The groves hold an incredible amount of polish and virtually eliminate splatter. This allows the polish to stay where it’s needed… under the polishing pad. Plus, you can polish longer without having to stop and reload your pad with polish.
The Sonus SwirlBuster™ Foam Polishing Pad acts like two pads in one. Under firm pressure, the pad acts like a medium cutting pad. With light pressure, the pad polishes out like a gloss enhancing polishing pad. You get the best of both in one pad!
The Second breakthrough is our Sonus SwirlBuster™ Clearcoat Polish. Based on our popular Sonus
SFX-2 Enhance Polish technology, Sonus SwirlBuster™ Clearcoat Polish includes a heat-activated acrylic filler that fills remaining swirl marks and glazes the paint for an amazing final finish.
Unlike most polish “fillers”, which wash away after a single wash, the water based SONACRYL™ polymer is very durable. It will stand on its own as a last step product, and it makes a great foundation for all other last step products (waxes and sealants). Sonus SwirlBuster™ Clearcoat Polish contains no silicones and no oils. It is 100% body shop safe.
For best results, the Sonus SwirlBuster™ Pad and Polish are designed to be used as a system. However, we have tested both products with a variety of other polishes, pads and waxes. They are thoroughly compatible as mix-and-match components with your favorite products.
The Sonus SwirlBuster™ Foam Polish Pad will be available in limited quantities on February 3, 2006. List price is $14.95 per pad.
Sonus SwirlBuster™ Clearcoat Polish will be available on March 1, 2006. List price is $19.95 for a 16 oz. bottle.
