Go Back   Autopia.org > Detailing the Man > Nutrition, Exercise & Health
Old 04-30-03, 12:59   #121 (permalink)
2001civicex- Heh heh, you didn't fool me for a second.
PrinzII- I still find the weight work your trainer has you doing SO incredible that I wonder if I'm misunderstanding. Do you mean to say that you:
Do 100 ab crunches/pull downs without stopping. Then rest, then do it again?
Do 50 presses without stopping. Then rest, then do it again?
BTW, I'm NOT putting YOU on the spot here, (or at least that's sure not my intention) but rather your trainer. I ASSUME that you're paying for his "advice/guidance", right?
I had the luxury of learning what to do/not do over literally THOUSANDS of workouts (and I sorta wrecked my shoulders by doing things the wrong way) and by reading dozens of books/ hundreds of magazines on the subject (most of which were full of misinformation). I've also known competitive bodybuilders and weightlifters who REALLY knew their stuff. I assume that most people would rather not waste years and incur injuries if it can be avoided. I get a little heated up when I think someone is getting crappy advice (let alone if they're paying for it).
Old 04-30-03, 02:26   #122 (permalink)
Autopia Master Trooper
PrinzII's Avatar
PrinzII is offline
Contact: Send a message via ICQ to PrinzII Send a message via AIM to PrinzII Send a message via Yahoo to PrinzII
The guy who is training me will have me doing strictly cardio. he isn't charging me for this. But I like to add the weights. Also, I have done the 100 crunches w/o stopping, then resting and picking it back up again. Same with the pulldowns.
Shift_Cactus!
Old 04-30-03, 02:40   #123 (permalink)
rightlane is offline
Skull crushers: I did a search and found a site 2fit.com that showed a video of skull crushers. I will try it out.
Thanks
Old 04-30-03, 02:45   #124 (permalink)
PrinzII's Avatar
PrinzII is offline
<<<< may be rethinking his strategy.
Shift_Cactus!
Old 04-30-03, 03:26   #125 (permalink)
94AccordSedanEX is offline
Contact: Send a message via AIM to 94AccordSedanEX
Skull crushers work great for Triceps, but it's always good to make sure somebody is spotting you for that exercise.
White 94' Accord EX
Old 04-30-03, 05:00   #126 (permalink)
thomasfl's Avatar
thomasfl is offline
Prinz, NYDetailer and everyone else working on getting in shape, I have to commend your effort and look forward to seeing your results. Taking control of your life is very empowering. Remember it is a marathon and not a sprint.
Old 04-30-03, 05:19   #127 (permalink)
Yeah, what thomasfl said
PrinzII- OK, now I have a clearer take on your weight lifting regimen. Glad to hear you're rethinking it, more
Short (?) lecture on muscle fibers: Muscle groups are comprised of a mixture of "fast-twitch" and "slow-twitch" muscle fibers. The f-t ones are the ones that really grow and are where most of your power comes from. The s-t ones are the ones that can have great endurance; they don't really grow bigger, they just learn to work LONGER. Think of how some long-distance runners look TOO "stringy"/scrawny (like they need a good hearty meal) and how male gymnasts and sprinters (who go pretty all-out for short periods of time) have lean but MUSCULAR bods. That's a so-so example, but generally you oughta concentrate on the f-t fibers, which should be worked for the 20-50 seconds (OK, MAYBE up to 90 seconds max). The big exceptions are calves- go for up to 2 minutes on them.
Bench press example: 2 seconds to push it up, maybe a second (or less) at the top, 3-4 seconds to lower it back to starting point= 5-7 seconds per rep x 8 reps=40-56 seconds per set.
Unless you have some specific goal in mind (like being able to do 50 pushups or 25 chins or something similar), you really do want to keep the reps sorta low.
Start off with 20 rep sets with a light weight while you learn good form. Proper form is the most important thing!! Slow is better than fast, and AVOID momentum/body english. (Feel free to ask about any exercises you'd like form-advice on.) Then raise the weight to where you can (only) do what I outlined above- >1 minute sets with strict form.
rightlane- Good searching! BUT.. once I got to 2fit.com, I couldn't find the video
The "trick with "skulls" (besides NOT bonking your head, see 94AccordSedanEX's suggestion if you're more sensible than I am, and you SHOULD be! I ALWAYS spot my wife's workouts) is to keep the weight heavy and the reps low. That will recruit the long head whereas it will "loaf" under lighter loads, allowing the other 2 heads of the tris to do the work (and they get work with most every OTHER tri exercise). Don't let your elbows flare out, even if it means using a lighter weight. Go for a REAL stretch at the bottom, like letting the bar touch the bridge of your nose for a count of "one". DON'T "bounce" at the bottom or you can hurt your elbows!! Grip the bar pretty TIGHTLY, it'll take strain off your elbows even more and stabilize your wrists. Oh, and you should pick up the bar with a THUMBLESS grip (thumbs BESIDE your index fingers, NOT curled around the bar like holding a hammer, this is AKA "monkey grip"). Then when you lie on your back to do the exercise, your palms will be facing UP towards the ceiling. Again, be careful, especially when you release the bar after your last rep. BTW, DECLINE benches give a better effective range of motion than flat ones because gravity pulls straight down (and the bar isn't over your head quite as much).
Old 05-01-03, 10:35   #128 (permalink)
PrinzII's Avatar
PrinzII is offline
Let's just say that yesterday's routine was a lot better.
Shift_Cactus!
Old 05-01-03, 10:38   #129 (permalink)
PrinzII- There you go
See if you get any soreness. "Delayed Onset Muscle Soreness" ("DOMS") is actually a GOOD thing! Well, as long as you don't overdo it, heh heh. Glad to hear your latest workout went well.
Old 05-02-03, 10:22   #130 (permalink)
PrinzII's Avatar
PrinzII is offline
Believe me, I got some soreness in my arms.
Shift_Cactus!
Old 05-03-03, 09:24   #131 (permalink)
PrinzII-
Old 05-03-03, 10:02   #132 (permalink)
PrinzII's Avatar
PrinzII is offline
Believe it or not, I did some skullcrushers the other day based on the definition given. He had me do one set of 5 reps at 210 lbs. I like that and think it will be a permanent part of my routine.
Shift_Cactus!
