11-10-08, 08:56
JohnKleven is offline
Anyone use a foam gun?
I recently purchased the Gilmour foam gun. I tried it for the first time the other day, and I'm having a hard time figuring out what all the hype is all about? It certainly isn't exactly a "Green" product, as I used about ten times the normal amount of soap. I always use the two bucket washing method, and I wash in our inside wash bay, so I haven't really had a scratching problem. I guess it might be beneficial if you're washing an extremely dirty vehicle, but it seem to wash a lot of soap down the drain. I bought it because it seemed like a neat tool, but I don't really see the point of it.
Just my two cents.
John
Once we do black, you'll always come back...
11-10-08, 10:12
@hotmail.com
integritydetail is offline
Re: Anyone use a foam gun?
It replaces the soap bucket in the two bucket system. It allows a quick way to presoak. It's definitely not a "green" tool. Green methods would be waterless or rinseless wash products. As far as your using 10 times the normal amount of soap: In the tank mix 3:1 water to shampoo, then set the slider to the 3rd hole from the left (4:1). that'll give you 1 oz per gallon on the vehicle and looks a little sumpin like diss:
http://i228.photobucket.com/albums/e...C/CIMG0258.jpg
http://i228.photobucket.com/albums/e...C/CIMG0259.jpg
I think I actually use less shampoo and water when I use mine.
Optimum Results demand Optimum Products*
*Great results can be achieved with any high end line. I use and recommend Optimum.
11-11-08, 12:10
auto_guy is offline
can you post a picture of the setting on the gun? i just want to make sure mines set on the same settings as mines currently uses a lot of soap also...
11-11-08, 12:52
Car Crazy
Lumadar is offline
I dilute the canister with mostly water as well as using the smallest soap output on the slide to save on soap use.
It does have its place, especially on muddy vehicles or those that have not been waxed and have a lot of clinging grime on the sides of the vehicle (think rain, snow, light mud, etc).
11-11-08, 04:21
Setec Astronomy is offline
Although I almost always set my gun for the "normal" 1 oz/gal as Integrity Detail does (OMG! we agree on something!), many members dilute the soap down much more than that. I probably use 2 or 3 times as much as a bucket wash, I have never taken the time to try to dilute it down more and soak for longer...I have to do that one of these days.
If you're tryin to be "green" by using less soap, and you're in a shop, a pressure washer might be a better way to "pre-wash" and remove most of the dirt without soap. The whole idea of the foam gun is to loosen and float away some of the dirt before you grind it against the paint with your wash media, many pros seem to use a pressure washer for that.
Grumpy like Ketch...
"Well, it certainly does!"
11-11-08, 08:33
Yes, we use a pressure washer in our shop. I haven't really found the foam gun to be very benificial.
John
11-11-08, 09:23
Noting that I'm probably the single greatest proponent of foamgun-centric washing, if you can wash marring-free without one I don't see any reason to use it. Pretty big "if" IMO, but hey...
11-11-08, 09:27
shine maker
ghost28 is offline
the Gilmour is Ok for foaming but not as effective as a foam cannon for a pressure washer....i run my Foam Cannon at its lowest setting basically and use about 1-2oz of soap per foaming....the foam is very thick and clings well allowing a good soak time....if my car is not super dirty then i just foam and presure wash and its spotless...if its dirty then i foam and wash using just a rinse bucket....works great....with the Gilmour i still feel the need for a wash bucket but it does help in pre rinsing..most of the time my Gilmour is used to blast wheel wells and engines with APC....
my .02......
11-11-08, 09:49
@hotmail.com
will put that up for you tonite
11-11-08, 01:30
BigAl3 is offline
once again... the foam gun is nice because you can use it as a pre-soak AND while you're washing (some use it for one or both reasons), where as the foam cannon is used for just the pre-soak. is it worth it for some... maybe, maybe not. IME... it is worth it, and someone like Accummulator who has the wash regimen down with it, has found it's worth and benefit... just like anything else, it's not for everyone...
11-11-08, 05:40
Clarity Detailer
Samjam927 is offline
Has anybody had any experience with the foam gun from Griot's Garage? I'm interesed in getting one and havent heard any word on if this one is worth it
CLARITY DETAILING
11-11-08, 05:45
BigAl3 is offline
that thing is not a foam gun but more like a soapy water gun... pass on it and buy a real one made by Gilmour...
