Originally Posted by auto_guy
can you post a picture of the setting on the gun? i just want to make sure mines set on the same settings as mines currently uses a lot of soap also...
Pics do help, but you need to understand how the ratios work, so you can adjust exactly how much soap to use. The simplest way to understand is to choose a setting on the gun. Then adjust your solution ratio in the jug to get to your final result of how much shampoo will land on the car.
For example, you would like 1 oz of shampoo for each gallon of water to hit the car. Setting the gun to 4 oz per gallon means exactly just that, i.e. 4 oz of "solution" per 1 gallon of H2O will hit the car. But you only require 1 oz of shampoo. What to do? Simply cut the solution in the jug so that of that total 4 oz coming out, only 1 oz is shampoo and the rest (i.e. 3 oz) is water. So, your dilution ratio in the jug will be 1:3.
Hope this helps.
