Results 1 to 11 of 11
  1. #1
    Fiberglass camper wax
    Join Date
    Mar 2001
    Location
    Cleveland Ga
    Posts
    66
    I just bought a 4 year old fifth wheel camper and wanna get it back shining.
    Apparently it's technically filon fiberglass and not really gelcoat.
    What is a good (preferably one step) product to use to get it looking food again? I plan on using a PC 7424 polisher for it.
    I've attached a picture to show you the camper.
    Thanks in advance.
    Attached Thumbnails Attached Thumbnails Fiberglass camper wax-flagstaff-004-small.jpg
    2006 Chevy 2500HD 4wd Duramax
    2005 Toyota Sienna LE
    2003 Toyota Corolla CE
    2005 Forrest River Flagstaff 30' Fifth wheel
  2. #2
    Re: Fiberglass camper wax
    Mike Phillips's Avatar
    Join Date
    Jul 2002
    Location
    Stuart, Florida
    Posts
    1,830
    A good one-step cleaner/wax should tackle that no problem, you should consider buying a gallon as that's a lot of real-estate to cover.
    Do a quick and simple test using some ColorX by Meguiar's. Apply to just a small section, work in well, let dry and then wipe off and inspect. If it looks more clear with good gloss then you're lucky and probably just about any quality cleaner/wax will work.
    If you run into any problems like hard application and wipe-off and it doesn't look good after you remove the residue then probably nothing will work.
    ColorX is fairly Bubba-Proof.
  3. #3
    BobD's Avatar
    Join Date
    Jan 2006
    Location
    Michigan
    Posts
    4,037
    Thanks in advance.
    Look at the Collinite line. It's what I use one RV's and campers.
  4. #4
    Join Date
    Jun 2009
    Posts
    42
    Duragloss #501 has great cleaning power with protection since you were asking about a one step. Jason(MotorCity) uses it on chrome trim also.
    Duragloss #501, Duragloss Marine / RV Polish
  5. #5
    Join Date
    Sep 2006
    Location
    O'Fallon, MO
    Posts
    6
    Thanks in advance.
    I have a 7 year old RV with the filon fiberglass. I use Meg's A12 cleaner/wax twice a year with a DA and a polishing pad. Still shines and beads water after all these years.
    Grab a six pack and take your time.
    Tom
  6. #6
    Join Date
    Jul 2006
    Location
    Upstate New York
    Posts
    823
    First you need a good cleaning. Then (now remember that fiberglass is cloth impregnated with a polyester resin = PLASTIC) use 303 Aerospace Protectant!
    Spray on, swipe with a paint brush and let set for awhile (but not long enough to dry out), then go over with a dry MF towel OR your PC. Periodically, just spray and wipe with 303!
    The beauty of 303 is not only does it maintain/restore the luster or sheen, but you can't get better UV protection.
  7. #7
    Join Date
    Feb 2010
    Posts
    69
    Just how good is 303 on gel coat?
    I have looked into this product more than a few times but could never quite figure out if it was a sealant, wax, or something else.
  8. #8
    Join Date
    Jul 2006
    Location
    Upstate New York
    Posts
    823
    It acts like a sealant and UV protectant. Treatment is different if the surface is faded (spray on and spread to soak - I've also read of using a pc to work in) otherwise spray on and wipe off.
  9. #9
    Join Date
    Feb 2010
    Posts
    69
    tnks, looks like I will have to give it a try.
  10. #10
    DESERTCITIES's Avatar
    Join Date
    Apr 2010
    Posts
    9
    3m Marine Polish Will Do Just Fine...trust Me.
  11. #11
    Nicky Papers's Avatar
    Join Date
    Mar 2010
    Posts
    37
    Garry's will do the trick on that. I've used it many times on RV's. It's a great one-step wax that will clean, shine, and protect.
  1. How-to Properly Wax Your Car
    By Autopia Expert in forum Guide to Detailing
    Last Post: 12-18-12, 12:49
  2. Judging how much wax to use?
    By bluemoon in forum Car Detailing
    Last Post: 09-08-09, 05:00
  3. Meguires Quik Wax
    By Craigmri in forum Car Detailing Product Discussion
    Last Post: 10-21-04, 12:49
Posting Permissions
  • You may not post replies
  • You may not edit your posts
