Old 10-28-09, 08:23   #1 (permalink)
JP Detail
vecdran's Avatar
vecdran is offline
Just got offered a boat detail...deer in the headlights look followed.
I need some advice Autopians. I recently got asked to quote a boat. It's some 23' foot beast or something of that nature. I've never done a boat before. I'm scared.
It has already been cleaned with marine wash, but my concern is the polishing...or as I'm rapidly reading, the compounding.
I currently use Menzerna polishes and Uber foam pads with a PC 7424XP. I am rapidly discovering, at least from the products suggested, that they won't cut it. (Pun intended.)
Do you guys think that Menzerna Power Gloss (which is what I have on hand) and a LC foamed wool pad would do it? I honestly haven't really look at the boat yet, so I don't know how bad the oxidation is, so who knows if I really will have to break out a rotary and a full wool pad.
Halp!
Boat newbie,
vec
2003 Subaru Impreza WRX Sedan - World Rally Blue
Old 10-28-09, 08:38   #2 (permalink)
Bright Dynamics Owner
Jakerooni's Avatar
Jakerooni is offline
Re: Just got offered a boat detail...deer in the headlights look followed.
you need a rotary to polish a boat. Especially one with oxidized gel coats. a D/A of any brand simply isn't powerful enough to do it properly. lots of wool pads. No foam.
Best advise..... Pass on the detail.
Old 10-28-09, 08:40   #3 (permalink)
VALE TUDO is offline
i agree PASS ive done 1 boat and i'll never do 1 again
Old 10-28-09, 09:01   #4 (permalink)
Zamboni for Paint
Greg Nichols's Avatar
Greg Nichols is offline
I like boat details as I get a great return on the work. You need a rotary if the boat has any oxidation. You need to see what condition the boat is in. You can do a light polishing with your PC, but use boat polishes. Just give yourself time to do your first couple of boats.
Cheers,
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
Old 10-28-09, 10:54   #5 (permalink)
flatstick is offline
I agree with Greg, check and see the condition of the boat first. if it is heavily oxidized you should pass on it. boats a take long time so make sure you charge enough and plan on it taking longer than you think. I do not mind doing boats as I own a 20ft bass boat. have been use to taking care of them and knowing how long it takes to work on them and what to do if you run across one that has been neglected.
Old 10-28-09, 11:06   #6 (permalink)
JP Detail
vecdran's Avatar
vecdran is offline
I've already told the owner that it will probably take me a solid week to do the boat, especially since it would be my first.
I believe the shop I will be doing this at has a rotary on hand, a Makita of some sort, I've just never used a rotary before.
Old 10-28-09, 11:27   #7 (permalink)
Proper prep is a virtue
howareb's Avatar
howareb is offline
Contact: Send a message via Yahoo to howareb
I also would suggest that you pass on the detail as previous posts suggested.
However if you are doing this at a shop and you have someone there with polishing experience, then you may be able to get them to help you. I would not try to learn how to use a rotary without some practice first. Typically a gel coat fiberglass boat will require higher RPMs than your typical car. This means that you have a higher potential of causing damage to the boat or yourself. In the end you know what you are capable of we can only give advice based upon best practices and experience.
Mint Auto Detailing LLC
Old 10-28-09, 11:34   #8 (permalink)
vtec92civic is offline
Boats are fun but very time consuming. If you are having second thoughts pass on it but if you feel that you want to give it a go then do so 110%
Boats can be challenging and depending upon how bad of a condition the gel coat is in.
Boats don't always need wool pads to come out nice. Got a buddy who used a couple of LC Yellow pads and the boat came out great even with bad oxidation.
What you want to do is #1 get yourself some boat products. I suggest using:
Meguiars #67 1 Step Compound
that should take care of what you are about to tackle. Then you can top it with something of your choice.
I would go with something like Collinite #845
take your time, take some pics so you can check your work after and enjoy.
Old 10-28-09, 01:09   #9 (permalink)
bige441 is offline
The only time I've ever used a orbital on a boat is to spread a LSP. A rotary is a must time and result wise. If you have never used a rotary I would advise that you pass on this one, but if the customer is willing to wait a few weeks for you to get some experience with one then it might be a good deal. With an investment of about $300 or so you will get a rotary and the products to do a boat and get the detail done and make an additional couple hundred bucks. Worst case you buy a buffer, some pads, a few different products and walk away from the deal with making nothing and losing nothing. You will however have a new rotary and the proper supplies to the next one and make the money you want. Bottom line, I would never try to learn to use a rotary on a customers car/ boat. I see that your in Mercer Island and I'm in Tacoma area and would be more than happy to help you out with some tips if interested.
Old 10-28-09, 02:08   #10 (permalink)
jose206's Avatar
jose206 is offline
Hey I would like some experience on boats big e, let me know if you ever need a hand!
Old 10-28-09, 07:52   #11 (permalink)
JP Detail
vecdran's Avatar
vecdran is offline
So much for my fear, the PC did the job here! Test panel as follows.
Sorry for the quality, only had my cell camera on hand. The oxidation wasn't too bad, and I was able to correct it with one pass of Menzerna Power Gloss, then another with Menzerna SIP to finish, both on an Uber Orange Foam pad (medium cut pad).
I was really fearing for the worst, what with all of you telling me I need a rotary, but it looks like a DA will cut it on this job.
However,the other boat I looked at today...that's swirled to all hell, in addition to some pretty nasty oxidation, so that just might take a rotary.
Thanks for all of the advice gentlemen!
PS.
Any of you recommend a good marine specific sealant/wax for the hull? I hear Collinite would work pretty well, but I think investing in a small bottle of some marine grade stuff just for this job would probably be wise.
Old 10-28-09, 08:05   #12 (permalink)
Leadfootluke's Avatar
Leadfootluke is offline
Rotaries, 3M products, Months of time.... haha.
Lots of headaches.
Dirty camera, sorry.
Anyone ever detail boats? geekysteve Professional Detailer General Discussion 14 07-31-04 08:05
boat detail few questions vwjettak2gti16v Professional Detailer General Discussion 3 06-12-04 12:12
First time boat detail - need help cwikone Car Detailing 4 06-04-04 11:22
I was offered to detail somebody's car... Corey Bit Spank Professional Detailer General Discussion 13 04-10-04 10:19
Interesting Read theveed Car Detailing 0 01-08-03 12:22
