if your using 49 you may as well skip the 200 wetsand...49 is fairly abrasive on its own and will cut just as deep as the 2000....use it on a 3M Woool Superbuff 2+2 pad...spin the machine at 1000rpm spreading theh compound and dont be afraid to use some product (this is not like a car where you only need a little product) once spread and wet buzz the polisher up to 2000-2500rpm and work a small section at a time....as the 49 breaks down it polishes up well......you may need to do it twice to get nice results on a crappy boat....
foam pads are a waste of time when trying to CUT on gelcoat....the 3M Superbuff 2+2 pads
flex alot more than any backing plate will and allow you to put heavy pressure on the pad which is what you need when polishing gel....
next step if you wanna get crazy is 3M finesse it on a yellow 3m wool blend polish pad also with the superbuff 2+2 adapter......
as far as auto sealants dont waste your time really..just use a quality cleaner wax as your first coat of LSP and then follow with collinite fleetwax.....
some guys on here have bitched that my process is TOO COMPLICTED but try it and master it and you will love it....
