Old 04-27-09, 12:56   #1 (permalink)
Formerly carn00bie
gofastman is offline
Meguiar's #4 or #84 for extreme fiberglass oxidation
my friend wants me to clean his boat up a bit, it has been very neglected and the exterior feels like chalk, Im thinking its gonna take some muscle to cut through this stuff, should I start out with one of these (#4 or #84) and a LC purple foam or orange pad on a rotary? I have never done a boat so I really dont know what to expect
also, once its cleaned up should I hit it with a paint sealant or something like 303?
Old 04-27-09, 01:34   #2 (permalink)
Mahi Killer
Brandon1's Avatar
Brandon1 is offline
Contact: Send a message via AIM to Brandon1
Re: Meguiar's #4 or #84 for extreme fiberglass oxidation
I had the same problem on a recent detail I have done.
Go to your local west marine and pick up 3M Rubbing Compound. Will have green letters. Its sand in a bottle. Also, pick up a wool compound pad, it will cut through the oxidation perfectly.
Showroom Shine Details
Premium Automotive/Marine Detailing
Old 04-27-09, 01:39   #3 (permalink)
Zamboni for Paint
Greg Nichols's Avatar
Greg Nichols is offline
I like to use 105 and wool. If you need something more agressive than 105, I go straight towards wet sanding! Got pics of the job at hand?
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
Old 04-27-09, 07:21   #4 (permalink)
Bright Dynamics Owner
Jakerooni's Avatar
Jakerooni is offline
Go get this kit and don't even bother with a foam pad on chaulky gel coated fiberglass... get big wool pads and lots of them. You'll be going through a ton of them in a poor condition boat.
I can show you some of my boat before and afters if needed but trust me you're in a for loooooooong few days to get it all right.
Old 04-28-09, 08:58   #5 (permalink)
shine maker
ghost28 is offline
the kit mentioned above with Wool is the best combo around....
Old 04-29-09, 11:00   #6 (permalink)
Jokeman is offline
Im using that kit on a 1973 MFG that is orange that has never been buffed. The boat is pretty much all white from being oxidized for so long. With the oxidization remover the gelcoat is coming out shiny orange again.
Old 04-29-09, 11:30   #7 (permalink)
Zamboni for Paint
I strongly sugggest that if the boat is very bad (chalky) that you use agressive sanding working your way down to say 1500grit then break out the polish. Compounding a boat that is bad takes more time than, wet sanding it............every experience I have had, its faster.
Cheers,
GREG
Old 04-30-09, 06:28   #8 (permalink)
Yamaha0219's Avatar
Yamaha0219 is offline
+1 for the 3M with the green letters, worked amazing on bringing back the hull (white) of my 1996 SeaDoo GTX, took 2/3 passes though.
I recently just did my 21' Crownline that has some black and some white. I used purple wool pad with M105 on my G110, worked wonders, never thought I'd see the black that black, however, it didn't work wonders on the white...evened it out but didn't get an amazing shine. Good Luck
Old 05-02-09, 05:51   #9 (permalink)
EastsideAutoSpa's Avatar
EastsideAutoSpa is offline
I hate wet sanding found a compund from Presta called Super Cut i cant find it on their site but they have it here Super Cut
or you can try this.......Gel Coat Compound
ive used Presta with good results they also say not to use either of these on cars, ive never tried espesscially after you feel the grit in this stuff....
-Paul
EastsideAutoSpa
Old 05-02-09, 06:00   #10 (permalink)
jrib is offline
The kit/advice mentioned above will be your best bet. The only thing I would ad,Wash the thing with A.P.C. you will not believe all the white crap that comes off doing this.This will surely save you a Pad or 3.Wet sanding should not be nescecary
Old 05-02-09, 06:44   #11 (permalink)
smprince1 is offline
For heavy oxidation on a gel coat, you need to get somewhat mideval.
Twisted wool, rotary, and a heavy cut marine compound are a must. Most likely wet sanding too.
Need to get way more agressive than you would ever dare on auto paint.
Old 05-02-09, 06:57   #12 (permalink)
jrib is offline
Yes, Medeval is called for from time to time
