04-03-09, 06:56
Detailer Wannabe
Konowl is offline
Boat Detail
I'm familiar with doing decent car details, but don't really know where to start.
Bought a boat last year, and I don't think it's even seen a coat of wax in it's life. It's been sitting in the water most of it's summer life so has a definate grime/seaweed line that i have no idea what to attack with.
I have no idea where to start and what to use. Local shops seem to carry 3M/Meguiars aquatic line. Seaweed line is the main thing I'd like to get rid of, and Ill need a wax that will last as this boat will be in the water a fair bit and will be parked on my boat lift. In the water.
04-12-09, 09:49
Five_Star is offline
Re: Boat Detail
Don't overlook a good Hull Cleaner! For polish, compounds, and wax, Meguire's is a good place to start..
You miss 100% of the shots you never take...
04-12-09, 11:43
Rhino is offline
Re: Boat Detail
Get a jug of muriatic acid at your local hardware store, along with some good rubber gloves and a face mask. Spray the bottom of the boat with the acid and aggitate it with a soft scrub brush on a broom stick. This stuff is highly toxic and hurts if you get it on your skin. DO NOT breathe it in! Also do not wear decent clothes while doing this, as it will ruin them. Very nasty stuff, yet extremely effective. I use it every summer on gel-coat bottoms. DO NOT use on painted bottoms.
04-12-09, 09:25
yanks_178 is offline
Re: Boat Detail
I have used toilet bowl cleaner to remove that stubborn crap on boats.. works quite well. The Meguiar's Marine line is the best to use. I've used 105 quite a bit but the best results are with the Marine line. You can pick up some oxidation remover and wax for under $30 usually.
04-12-09, 09:46
bige441 is offline
Re: Boat Detail
I agree with the megs stuff good stuff for a resonable price. I also suggest putting on some anti fowling coating( the black paint on the bottom). A little bit of money butreally helps keep the bottom nice and clean.
04-13-09, 08:09
steck is offline
Re: Boat Detail
if you didnt want to go 'chemical' route, you can go with 3000 grit and lots of water, to get rid of that scum line...
04-21-09, 12:35
Zamboni for Paint
Greg Nichols is offline
Re: Boat Detail
Don't you need to dilute it 3:1 or less? I would be scared to run it straight!
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
04-21-09, 02:15
When quality matters!
Premium is offline
Re: Boat Detail
Diluted Muriatic acid is called hydrochloric acid. No, full strength will work best, but diluted should work also. If the staining is light to moderate go ahead and dilute, but for heavy stains on gel coat you could use it straight.
My first try would be Soft Scrub and if that doesn't work hit it with some compound. Acid should be your last resort.
P.S. I do boats regularly.
04-21-09, 06:11
EastsideAutoSpa is offline
Re: Boat Detail
-Paul
EastsideAutoSpa
