Re: Blue pipe blues
hey there
sure you are aware the blue comes from the heat of the exhaust.
same thing happens when welding Stainless Steel, there a acids that will remove the blue very easily (phospheric acid works)
((((((BUT))))))))) I have no idea if it is a chrome plated exhaust
((((((AND))))))))) I have never used on a cycle exhaust, but it works quite well on the stainless I weld.
I also use it to remove rust stains on the gelcoat finish of boats, but wonder if paint might not be damaged by it. If applied carfully it should work well on a stainless exhaust and probably on chrome too.
