10-13-08, 07:06
BAKER is offline
Scuff Marks on Boat
Neighbour has scuff marks on the hull of his boat, looks like it might be from black rubber scuffing against the wharf. Will Isopropyl alcohol take this off or should I try a polish with the porter cable.
10-13-08, 10:51
murf'n'surf is offline
Re: Scuff Marks on Boat
It should rub off with your finger when dry. If not, hit it with a mild compound.
10-15-08, 07:13
yachtfisher is offline
I would try some denatured alcohol, works well
some cleaner wax on a white scott brite pad works also
there are also black mark remover products at the marine store
Mark
10-15-08, 07:43
BAKER is offline
The alcohol didn't work, nor bug ans tar remover, so I hit it with XMT 2.5 swirl remover and it came right off. Thanks for the suggestions though.
10-23-08, 12:19
cole is offline
Petrochemical solvents such as gasoline, Kerosene and even paint thinner remove scuffs easily. You need to clean off the petrochemical residue, but you are likely going to be washing the boast anyway.
Regards from Arizona,
Cole
10-23-08, 06:54
JohnDeere is offline
meguiars scratch x removes paint transfer from other objects using diminishing abrasives and creates opticla clarity. using gasoline, kerosene or rubbing alchool is stupid and pointless. megs scratch x is 9.99 a tube, use it with a terry cloth or even a microfiber, dont be dumb and rub ur cars paint with gasoline
10-24-08, 12:14
has left the building
JuneBug is offline
I'd try an APC or maybe 409 if it's from the rubber rollers on the trailer.
10-27-08, 12:22
cole is offline
It's not a car - its a BOAT and many high powered cleaners for CARS are based in petroleum distillates- read the labels. I use paint thinner often to clean the scuffs from wooden docks and bumper rails off the sides of my 24 foot boat which has a 50/50 mix of gel coat and boat decal graphics. Quick and easy, followed by Collinite boat cleaner and a coat of Collinite wax. In 10 years, the gel coat and decals are like new.
Cole
11-04-08, 01:49
BlueLibby04 is offline
2004 Jeep liberty w/ stuff.
12-31-08, 12:24
AndyA6 is offline
Anybody tried Mr. Clean Magic Eraser? Worked for me like a charm on exactly those marks in the above pics!
12-31-08, 06:31
The magic eraser may marr the finish while it removes those scuffs.
01-01-09, 05:36
shine maker
ghost28 is offline
if its on Gelcoat use Acetone it will take them right off...if its paint test it first in an inconspicuos area...most IMRON will hold up to it just fine....just be sure to throw some wax over it afterwards cause the Acetone wil take the wax right off....
