Originally Posted by David Fermani
Did this scuff break through the chrome plating? If so and it's rusting, there's really nothing (aside from re-chroming) that can be done to correct the problem. You could spray it down with acid and then neutralize it with APC to clean out the corrosion and then polish/seal to keep it preserved.
No the scuff did not break through fortunately. I never thought of using acid. Would the acid that is sold by AutoInternational's or Finish Care's Paint Decontamination systems work? If not, what type of acid would you suggest?
Once I get the acid I assume the process should be:
1. Use steel wool to remove all visible rust.
2. Spray acid on the area the rust was and let dwell for 10 minutes.
3. Spray APC on the area to and let dwell for 10 minutes to neutralize the area.
4. Wash area with a strong mix of car wash
5. Polish with Chrome Polish
6. Seal with a quality sealant.
Does this sound correct?
