Old 04-15-08, 09:54   #1 (permalink)
1988wellcraft21 is offline
Struggling with my gelcoat, looking for advice!!
Hi all! Just joined the forum looking for some advice...
I have a 1988 Wellcraft (hence my username! so clever), with a red hull over white. As you can see from the photos, the red has loads of oxidation. The past several days, I've been spending TONS of time and effort (and $$) trying to even this out and restore the color and gloss. I've been focusing on the port side only, hoping I'll perfect my technique for the startboard side and cut my work time down accordingly.
Here's what I've tried...
- Wetsanding with 600, then 1200.
- Then, compound using 3M Super Duty Compound
- Then, polish using GelCoat Labs fine cut polish (from properboatcare.com)
Doing this all with a 1750 RPM, 11amp rotary buffer (Milwaukee 5460-6). Also using Wool compounding pad for the compound, and a softer wool pad for the polish. I have foam pads, but I haven't tried those yet (difference?).
Here's what I've accomplished... There's certainly a big improvement, but my current state is very uneven. There's areas of nice color, mixed with areas of splotchy oxidation. It doesn't look right. I'm terrified to wet sand too much and wear out the gel coat... is this a real risk? Should I wet sand differently? Different grits of sandpaper? So many variables!
I've included some pictures. First, the shots of where she stands now, after what I've done above.
And here's a couple shots of the starboard side, so you see what I'm up against...
I'd really appreciate any advice, thanks for looking!
Old 04-17-08, 12:33   #2 (permalink)
Kmhawaiidh's Avatar
Kmhawaiidh is offline
Re: Struggling with my gelcoat, looking for advice!!
Sometimes in that situation I found that changing pads more frequently helps reduce the splotchy effect. I just did a 35' 5th wheel it took 12 CCS Foam pads. Or change compound it might react better with the gel coat.
Old 04-17-08, 01:38   #3 (permalink)
To Shine and Protect
salty's Avatar
salty is offline
Hard to see in the pics. The done side does look a lot better. The boat is 20 years old, not sure if it can be brought back much more.
Your approach is very aggressive and should show the max you can get out of your gel coat.
X-Kote would make it look better, not sure if anyone does it in your area.
Mark
deluxedetailing
Old 04-17-08, 04:27   #4 (permalink)
warlockid's Avatar
warlockid is offline
Id try an AIO, like Opti-Seal or even Klasse AIO with a wool pad cutting pad. I use One Shot, by Mark V, on a lot of gelcoated RV's because I can get it local. As Salty said, its 20 year old fiberglass. Looks much better than you started with, thats for sure
Deeper the thought, the deeper the shine
Old 04-17-08, 07:22   #5 (permalink)
The Detail Shoppe
RDAVEX7's Avatar
RDAVEX7 is offline
Have you tried IMAR yacht polish? Dont know if it would take care of heavy oxidation though.
Quality Doesn't Cost, It Pay's
Old 04-17-08, 07:31   #6 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
did you see this?
http://autopia.org/forum/click-brag/...-products.html
Old 04-18-08, 01:55   #7 (permalink)
Thanks for the tip, I will try a clean pad on the area I've worked on already, and see if the splotchiness is better. I have changed compounds, to 3M Super duty, with no apparent change. The compound just doesn't seem to do much at this stage.
What's remarkable is that, with some more aggressive wet sanding, compounding, polish, and Klasse AIO, I've gotten the area ABOVE the rubrail (the red part) almost perfect. It looks quite beautiful, actually. But i just can't seem to get the freeboard to match! No matter what I do, some whitish areas still persist, even though they are actually glossy! So bizarre...
Salty... I realize the pics don't do it [in]justice... In a couple of them though, if you look closely, you can see that especially the lower part looks white. In reality, that whiteness is vastly more obvious. I could definitely agree with you that it's hard to get much more out of this fiberglass. perhaps it's just too far gone to make perfect. Nonetheless, I keep trying!
Warlockid... I've already have the Klasse AIO. I've used it on the aforementioned areas above the rubrail to preserve that non-oxidized shine, but I don't think it will add much to areas that already have oxidation. I applied it by hand, though... can this be applied by machine? I also have foam polishing pads that I haven't tried yet...
RDAVEX7... can't say I've tried that, but I'm trying to avoid spending more $$ on experimenting. Thanks all the same.
BigJimZ28... I did see that post, and studied it carefully. It looks like he did multiple compoundings, in addition to some pretty aggressive wetsanding. He got incredible results! I'm wondering if it was a bit easier to restore being that it was yellow (lighter color), so oxidation doesn't show as badly. Red is supposed to be the worst (yay!). My boat shines, but the color is just so uneven...
Thanks for the tips so far, keep 'em coming if you have any more ideas!
Old 04-19-08, 09:52   #8 (permalink)
Moutee's Avatar
Moutee is offline
I don't know why I've never posted in this sub-forum before, but I STRONGLY suggest buying Aquabuff. It will save you hours with and is very easy to use. I don't have very good before/after pictures, but I'll give you what I have.
Stripe of boat before
Stripe and hull after Aquabuff 1000 and 2000 (No LSP yet)
Old 04-20-08, 07:53   #9 (permalink)
purplenurple is offline
Try the Megs #49 Heavy Oxidation Remover - pretty effective with an orange pad, but requires multiple passes. I would use it with a heavy vut pad or even wool.
Old 04-20-08, 10:24   #10 (permalink)
Flygti32 is offline
Contact: Send a message via MSN to Flygti32
I would break out a white wool pad and Megs #4 heavy cut cleaner. Once done that step I would clean it and X-Kote it.
I did this one in Vegas last Aug on a training seminar.
to this
Old 04-21-08, 06:51   #11 (permalink)
Mahi Killer
Brandon1's Avatar
Brandon1 is offline
Contact: Send a message via AIM to Brandon1
I will chime in with my 0.02c worth.
It may be me, but I wouldnt wet-sand that boat. Your finish is already 20years old, wetsanding may be taking away what little gel-coat you have left. I've worked on boats my entire life, and on situations like that, I like to coat the boat in #7 Megs and leave it overnight. Then come in with a strong AIO like Klasse or Duragloss Marine polish to remove the oxidation, Then coat in #7 again. Then apply your favorite marine sealant.
Showroom Shine Details
Premium Automotive/Marine Detailing
Old 04-22-08, 02:51   #12 (permalink)
Lurker Extraordinaire
Sherri Zann's Avatar
Sherri Zann is offline
Brandon,
This weekend I'll be starting on my 25 y.o. sunfish--white, but badly oxidized.
Unclear how #7 would help here as it is a pure glaze with no abrasives, or so I thought. Can you explain how it helps get rid of the oxidation? Or is is just re-hydrating the oxidation or something like that?
