Old 01-05-08, 12:58   #1 (permalink)
Detailer Wannabe
Civicman86's Avatar
Civicman86 is offline
Contact: Send a message via AIM to Civicman86
Polishing Motor Cycle??
My dad has two harleys that he wants me to polish to get rid of the marring from using a crappy sponge when cleaning. What is the best way to do this? Most of the panels are small so I thought it would be hard to do with a PC?
I'm going to be using Menz. probably just 106ff. Maybe SIP if 106ff can't fix it.
-Dustin
Check out my cars progress from beginning to end...
http://autopia.org/forum/click-brag/...ining-end.html
Old 01-05-08, 01:03   #2 (permalink)
smprince1 is online now
Re: Polishing Motor Cycle??
Try 4" pads...they are available for both PC and rotary.
Old 03-04-08, 11:12   #3 (permalink)
CustomBikeMike is offline
Contact: Send a message via Yahoo to CustomBikeMike
I'm no expert, but sometimes the small panels show less than a big slab like a car body. What color?
Mike
Old 06-01-08, 11:44   #4 (permalink)
Harry Houdini's Avatar
Harry Houdini is offline
this is way to late, but I would try a finishing pad for example, because most
bikes have a very soft clear on them, use the LC red pad first with 106FF
see what happens, if that does not work them try the white one.
I would use Menz 85rd instead because it has no fillers, if 106FF is not worked
good and checked with ISO wipe down it might fill instead of removing.
Old 06-06-08, 06:43   #5 (permalink)
nighttraingirl is offline
You are going to have to use 4" pads or go it by hand. I use optimum products. Polish, Compound and Hyper Compound. I just don't see how you are going to correct any signifigant marring without the 4" pads. If it's really bad, and along the tank panels on a harley, you will have to loosen up the nut on the dash and polish underneath. I find a lot of bike owners have a tendency to wipe along the lines of their tank panel and or gas cap. creating a ton of linaear swirls which cannot be removed without the removal of the aforementioned items. Even if you choose to remove all these marks I can all most guarantee the will be back if you ever detail the bike again.
Old 07-11-08, 09:01   #6 (permalink)
veeko is offline
i just purchased some optimum polish. can't wait to see how well it works.
Old 08-30-08, 02:47   #7 (permalink)
WATERLESSDETAIL
waterlessdetail is offline
Ive heard that optimim is pretty good....let me know if this is true
Old 09-07-08, 02:06   #8 (permalink)
Shinier than thou
qwertydude is offline
M105 works wonders by hand, use a cotton cloth for some real cutting action. It'll get rid of the marks and then go to a foam applicator by hand with the M105 and it should finish off great.
Old 09-12-08, 10:00   #9 (permalink)
trig's Avatar
trig is offline
Is it not possible to put pressure on the edge of the pad, like maybe a white Lake Country pad with a wax on it?
I have some swirling on my bike but even a 4 inch pad will not fit in the slot and sit flat. Or, is the best option to use a foam hand pad?
Here's a pic. I'm talking about the dip on the tank in front of the gas filler-upper...
And here's a couple pics from the last time I washed the bike. :-)
