Originally Posted by MrDummy
Oh and my Biggest thing to whomever can help me out, is that I want all these marks gone on a more permanent level. I know I could just hide them, but I would want them to be corrected so I can have a solid base to start with. Then I can maintain it from then on out to not get into this kind of condition again.
thanks
Any good detailer in the area should be able to remove the defects without simply hiding them with temporary products. If the detailer can't explain the products they plan on using / don't tape off edges and sensitive areas (like trim), doesn't have the plans on doing a test section, and doesn't plan to use any type of post-polishing testing (such an an alcohol wipe-down or such) to test for true correction, those are things, IMO, you need to be worried about.
