I just applied my first coat of
SG and am waiting for it to cure. I poured 1 ounce of SG into a small clear plastic squeeze bottle and used a bit less than 1/3 of it. So I project I should get 3 coats per ounce - not bad I say.
Of course at this thinness the coat is pretty much invisible except for a few areas here and there. I was wondering if I'd have a mental problem with the whole "have faith it's there" concept, but I guess I don't! I know I'm applying
something even when the application looks and feels a bit dry because in certain lighting you can see it go on and flash dry almost instantly. I used a Megs foam app and Eagle One WET Wipe 'n Shine to help.
One interesting thing about the EO QD is that it even says on it that it's good for applying polishes and waxes (not sure if other QDs say this). So hopefully I won't have a problem with it since several people recommend
dry SG application. I also found I didn't have to spritz any QD on for longer than I thought because after a while I started touching the pad periodically and found it was staying moist for a long time.
The only thing I forgot was my idea to only SG half the hood for comparison
Oh well.
