06-11-08, 09:32
yachtfisher is offline
Join Date: Apr 2008 Posts: 11 | favorite product - remove yellowing/gel coat hey guys
looking for some info on your favorite products to restore white gel coat that has turned yellow. these by the way are not negelected boats, they see regular washes and waxing.
the two main problem areas are factory molded non skid decks and smooth large flats sections that get sun beat.
got any miricle cure products, and how is the longevitiy once corrected.
thanks mark | |
06-12-08, 04:04
Anomaly is offline
Join Date: Jul 2006 Location: Disneyland Posts: 117 | Re: favorite product - remove yellowing/gel coat I've had luck with Menzerna Power Gloss on 5.5" orange pads followed up with Klass AIO on 5.5" white pads and a PC.
The PG really helped out on the colored sections of the boat. And the KAIO worked very, very well on the white top section of the boat.
Unfortunately, I don't have any pics.
2004 Daytona Blue Nissan 350Z Touring | |
06-16-08, 04:32
Join Date: Apr 2008 Posts: 11 | Re: favorite product - remove yellowing/gel coat thanks much for the reply.
was hoping to hear some others.
any molded nonskid deck cure for yellowing
Mark | |
06-16-08, 08:00
| | "Zamboni for Paint"
Greg Nichols is offline
Join Date: May 2006 Location: Logan Utah Posts: 699 | Re: favorite product - remove yellowing/gel coat Most yellowing is below the suface of the gel coat, in many cases you have to remove down to that point.
__________________ Rain is caused by high pressure areas, cold fronts, warm moist air, a newly washed car, and the first day of your vacation. | |
06-16-08, 08:03
| | "Zamboni for Paint"
Join Date: May 2006 Location: Logan Utah Posts: 699 | Re: favorite product - remove yellowing/gel coat I like 3m super duty compound for heavy oxidation. I like wet sanding even more 1500,2000.2500
06-17-08, 04:29
Join Date: Apr 2008 Posts: 11 | Re: favorite product - remove yellowing/gel coat Yea wet sanding is the ticket
the non skid is killing me though, it is an agressive factory molded deck surface with a pretty deep profile and i can't get it white.
thanks
mark | |
06-17-08, 04:39
murf'n'surf is offline
Join Date: Feb 2007 Posts: 43 | Re: favorite product - remove yellowing/gel coat You may have no choice to get it painted. I have run across this myself -- the non-skid areas seem to lack the thickness of gel and discolor quickly. Have you tried a solvent in a small area just for giggles? | |
06-17-08, 06:21
| | "Zamboni for Paint"
Join Date: May 2006 Location: Logan Utah Posts: 699 | Re: favorite product - remove yellowing/gel coat I'm still learning about dealing with gel coats, but I'm thinking that there must be a chemical that will help reduce this.
I know there are "acids" that you can use on the bottom of boats to clean off the gel coat areas that you cannot easily reach with a buffer.
GREG
06-18-08, 04:53
Join Date: Apr 2008 Posts: 11 | Re: favorite product - remove yellowing/gel coat there are some chemicals in marine use for stain removal, most are oxalic acid based, the one from interlux (states) rust / diesel soot / yellowing (works well for the first 2 concerns did noting for the yellow.
I have used soft scrub with bleach (great non skid cleaner) and let sit for 1/2 hour, it failed completely. Used west marine non skid cleaner (completely worhless) and the interlux heavy duty stain remover.
I am thinking solvent lightly soaked on a rag and brush or scotch bright may be the last resort.
thanks
mark | |
06-18-08, 06:38
| | Glossy Tundra
Brandon1 is offline
Join Date: Jan 2005 Location: Wrightsville Beach, NC/Louisburg, NC Posts: 1,860 | Re: favorite product - remove yellowing/gel coat You may want to try Woody Wax. They have a cleaner for non-skid and a sealant that seals the look in!
__________________ SHOWROOM SHINE DETAILS
YOUNGSVILLE, NC 2003 Toyota Tundra Trd 4x4 20" Enkei rims, Toytech 3" lift, Borla exhaust. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 10:49. | | | |
