Old 03-03-07, 06:53   #1 (permalink)
03silvaevo's Avatar
03silvaevo is offline
Floor jack fixable?
I got two floor jacks. One is a 3 Ton sears jack(love it and still working in good order) and the other one is an MVP superlite that I've had for 5 years. This is the one that doesn't jack up at all when under the car. Before I trash this thing I was wondering if its possible to fix it. I don't think its got leaks or rust(maybe just the wheels).
2003 Mitsubishi Lancer Evolution VIII
2009 Toyota Camry SE
Old 03-03-07, 08:26   #2 (permalink)
Guy
Walk a mile in my shoes!
Guy's Avatar
Guy is offline
Contact: Send a message via Yahoo to Guy
Re: Floor jack fixable?
Check to see if it has enough fluid in it, the easy fix. A bit harder fix but not that bad, check the seals, one of those might be leaking. I fixed an old jack I had it's not that hard. Hardest part might be finding a new seal. Hope this helps and remember to use jack stands!
07 Kia Sportage EX
07 Kia Rio
Dodge Dakota 4 door 4x4
Chrysler 300m Sold
92 Dodge Stealth RT TT Sold
Old 03-03-07, 09:22   #3 (permalink)
mikebai1990's Avatar
mikebai1990 is offline
Chances are it's simply a lack of fluid or air in the system. Purge the system, and then add sufficient hydraulic oil.
Old 03-03-07, 02:36   #4 (permalink)
03silvaevo's Avatar
How do I go about purging air from a jack? Just loosen that pressure release bolt at the back and just pump jack several times?
Old 03-18-07, 03:19   #5 (permalink)
Changeling is offline
When you check the fluid level, if it needs fluid, use the fluid specified for floor jacks. NOT automatic trans fluid, break fluid, etc, !
Don't fill to the top! leave a small airspace, usually about 3/16 of an inch.
If it is the fluid level after checking, drain all of the old fluid out and get the correct fluid, not kidding, these things are not toys, respect it!!
Changeling
Old 03-18-07, 03:29   #6 (permalink)
Don't fill to the top! leave a small airspace, usually about 3/16 of an inch, but get the correct specification.
Changeling
I forgot to add, if you don't believe me than contact the manufacture, you can probably find them on line. They will give you the correct fluid number/manufacture number to use. Please just do it! The correct fluid is cheap!!!
Changeling
