Old 08-22-06, 12:26   #1 (permalink)
Carnauba for Life!
JM19's Avatar
JM19 is offline
Impact Wrench
I am looking for an impact wrench to do light-duty work on my car, specifically the removal of lug nuts when it comes to doing tire rotations. Does anyone have a recommendation for a unit that will be used at most two to four times a year?
Jeff
Old 08-22-06, 12:29   #2 (permalink)
Go Tigers!
TigerMike's Avatar
TigerMike is offline
My dad and I use Campbell Hausfeld with his compressor...looks like this one, and generally works well. Only problems we have are if the lugs are overtightened or almost welded on due to heat. They will eventually break free, but not without a little fight.
http://www.campbellhausfeld.net/weba...egory_rn=10562
2003 G35 - protected & perfected with Zaino [Zaino, made for those who refuse to live in a world full of compromises]
Old 08-22-06, 01:29   #3 (permalink)
Carnauba for Life!
JM19's Avatar
JM19 is offline
Do you know of anything that wouldn't require the use of air?
Jeff
Old 08-22-06, 01:32   #4 (permalink)
mikebai1990's Avatar
mikebai1990 is offline
I don't know much about impact wrenchs, but I just wanted to give you a little tip: Using a torque wrench to tighten lugnuts will prevent rotor warping, ensure even tightness, and make it easy to loosen the lugnuts next time.
Old 08-22-06, 01:44   #5 (permalink)
TaG 125cc
kompressornsc's Avatar
kompressornsc is offline
I can't think what they are actually called, but you can buy a socket set that has a special handle with it that you hit with a mallet. It spins the spindle of the socket, while the handle stays put. And I know that this is not making a bit of sense, but yes, what you are looking for does exist - I had to use a friend's to remove some old brake rotors.
'06 Honda Ridgeline
Old 08-22-06, 01:50   #6 (permalink)
Go Tigers!
TigerMike's Avatar
Oh, under the impression you had a compressor, sorry.
Try these: there are a few options, with some electric and some cordless, mixed in with the air driven.
http://www.sears.com/sr/javasr/searc...=impact+wrench
Old 08-22-06, 01:50   #7 (permalink)
Danase's Avatar
Danase is offline
I got a Chicago Eletric from Harbor Freight. It is electric and works great for what you are looking to do with it. I have had mine for about 8 years or just under with no troubles.
Old 08-22-06, 01:50   #8 (permalink)
ShineyWhiteRex is offline
Most tool manufacturers make Electric (some say Cordless) Impact Guns. I would check with Harbor Frieght for a deal.....it all depends on who's quailty you like warrenty etc that will determine the price. Harbor Frieght usually has no name cheap ones or you can go with something like Snap-On or Matco. Just be aware that they are not as powerful and you should definetly get more then one battery so you can charge one and use the other..... and mike has a good point, definetly tighten with a torque wrench to the proper specs, dont use an impact!
Old 08-22-06, 01:55   #9 (permalink)
Carnauba for Life!
JM19's Avatar
JM19 is offline
I have a torque wrench on hand. I'm buying an impact to correct the mistake of the technician the last time I had my tires rotated. In addition, I'd like an impact wrench in my arsenal just in case I have trouble getting them off again.
Jeff
Old 08-22-06, 01:56   #10 (permalink)
Not a noob, but close
reldridge is offline
Sears makes and sells impact wrenches, just like drills. Cordless or corded.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Ryan
Old 08-22-06, 02:19   #11 (permalink)
Who? Me?
the other pc's Avatar
the other pc is offline
Cool
Since you don't have a compressor I'd recommend a plug-in electric. They provide way more torque than the cordless models and you never have to worry about charging batteries or replacing dead ones.
PC.
Old 08-22-06, 04:43   #12 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
I also have a Chicago Eletric from Harbor Freight
and use it all the time
it is cheap and works well
and it is on sale like every other week!
I see you are in philly
I am in Levittown if you want to take a ride up 95
you could check out mine if you want
or stop by the Harbor Freight store near Franklin Mills Mall
