Old 02-05-02, 05:40   #1 (permalink)
Student in detaling arts
Iowan_Juggalo is offline
Contact: Send a message via AIM to Iowan_Juggalo
Oil
My car is sadly a oil leaker. It should be fixed soon. But what i what I am wondering is how will i get the old oil stains up. I have tried revive a drive but it didnt work. Please help
My Ride: 1997 Pontiac Sunfire (4 doors)
Old 02-05-02, 07:44   #2 (permalink)
Missing In Action
puterbum's Avatar
puterbum is offline
Contact: Send a message via AIM to puterbum
Try Simple Green and a stiff brush. Worked pretty well for me. I'm sure there is better stuff but you can't go wrong with trying this out. Just make sure to wipe down the area with a wet rag afterwards so it doesn't get slippery when wet.
Justin
2002 Sebring Silver Honda S2000
Old 02-06-02, 07:25   #3 (permalink)
Insert joke here ________
Guess My Name's Avatar
Guess My Name is offline
look for a thread called detailing the driveway it had lots of tips in it.
Neat Vehicle Freak
My Truck Album
2002 Chevy Avalanche
Old 02-08-02, 10:32   #4 (permalink)
Under Pressure
laynlow's Avatar
laynlow is offline
Contact: Send a message via AIM to laynlow
The easy route will be to rent a HOT water pressure washer and a surface cleaner. The rental place should also have the proper chemicals for your need.
My cold water unit does a good job, it just takes time. A hot water unit will emulsify (sp?) the oil much quicker.
Old 02-08-02, 02:52   #5 (permalink)
Thanx guy But I dont wana rent sumthing. I think i will scrub with a degreaser. But first it has to ge warmer.
Old 02-10-02, 12:53   #6 (permalink)
buldog's Avatar
buldog is offline
Have tried a couple of things in the past.
1) If the spill is outside where the sun can reach it, put down several layers of newspaper and soak the paper with water.
Hold paper down with some bricks and let the paper completely dry up. The oil gets pulled into the paper when the water evaporated.
2)Have some absorbal around all the time, these granuals will soak it up.
3)Simple Green will clean up the rest.
Check out this web site: http://www.homestore.com/Cargarage/Garage/Fstained.asp
Old 02-13-02, 12:32   #7 (permalink)
MTS
MTS is offline
I have found on oil stains that WD40 sprayed genereously on it, work it around a bit to soften. thins out the "dried" oil, then put some cat litter on and let it sit for a 1/2 day or so to soak up the wd40 and the thinned out oil - redo if not happy - it works for me. MTS
