First Painting/Baking... good results?
Just for s's and g's, i took my rear wiper arm off the car (was chipped, peeling, cracking)... i used aircraft paint remover to completly strip all of the paint off, so now it's all down to the bare metal.
i went over it with a fine sanding sponge to scuff it all up...
i always heard about baking paint in the over to speed up drying/curing time... so i decided to foil up a cookie sheet, lay the arm on it, and give her a light coat... then throw it in the oven at 200 degrees for 10 minutes before i give it it's next coat.
i plan on 2 color coats, and 2 clear coats. 10 min in the oven after each... and 30 min in the over on the last coat.
Thoughts on this? and i doing this complely wrong and will turn out like crap? or what?
Thanks for the comments all.
