03-08-05, 06:07
i'm on quack
Kanchou is offline
checklist input
suggest an order to the following garage projects & explain why.
replace cheap window with inert gas windows
re-wire phone/home networking/cable with nice conduits
Paint garage
etch & re-lay floor
install insulation
sheetrock
03-08-05, 06:10
TW85 HHI is offline
1) Replace cheap windows with inert gas windows
2) Rewire phone/home networking cable with nice conduits (not sure why you want nice conduits if they'll be in wall. If out of wall, then do this after sheetrock and then paint the conduits).
3) Install insulation
4) Sheetrock
5) Etch and lay floor
5.5) Cover freshly installed floor with paper using painter's tape.
6) Paint garage
Or do you enjoy working backwards?
03-08-05, 07:22
i'm on quack
Kanchou is offline
no, I am poor.
such decisions must be tempered when you're poor.
03-09-05, 08:46
OGauge4Me is offline
4) Sheetrock
6) Paint garage
Just curious as to why painting would not be step 5 rather than 6? Seems to me that of there was a mistake, paint can tipped over, it would be better if it did not happen on a tile floor.
03-09-05, 08:52
JBM is offline
What is the floor covering, tile?
03-09-05, 09:10
TW85 HHI is offline
By painting last, it would allow whatever is used on the floor to be carried up to the drywall instead of up to the baseboard (nicer appearance in the end). Secondly, I think there is less risk of damage to the floor (if properly covered) than there is to freshly painted walls if the floor was the last step.
03-09-05, 09:12
Thanks I am curious as I will attempt to my garage this summer and this is good information to know.
03-09-05, 12:17
i'm on quack
Kanchou is offline
no tiling for me, just laying down some cover on the floor.
And the reason i wanted to ask about order was because I don't think i want to have the wiring I'm going to redo actually in the wall or anything, I think I want to use an exposed conduit so i can get to the innards of the wiring later.
wires that need cleaned up or modified:
handicap lift switch
garage door switches
lan
phone
lg59 catv
lg6 sat
03-09-05, 12:29
TW85 HHI is offline
If you are absolutely sure you want the wiring to be in conduits on the outside of the wall, then do the wiring after drywall but before paint. I would personally paint the conduits to match the walls.
03-09-05, 01:50
lan
phone
lg59 catv
lg6 sat
Kanchou:
Check out the Panduit line of connector solutions. I have used them in the past and it makes a clean install. there is a connector for RG59 but i do not know what type of connector lg6 is.
http://www.panduit.com/products/
03-09-05, 02:55
i'm on quack
Kanchou is offline
i'm sorry, I got crossed up with computer wires. you're right, its rg59 and rg6. they're both coax lines but rg6 is a higher standard. it typically used in burial cable from the cable company before it gets to your house, or its used in your house for Sattelite/digital cable runs.
03-10-05, 09:38
Wax Sniffer
zippymbr is offline
I would etch and paint the floor first. any cleanup from drywall and paint that gets past the drop cloth will be easy to clean.
