12-17-04, 01:01
Carnauba for Life!
JM19 is offline
Lug nuts are on way too tight...
Well, I'm about to get ready to rotate my tires, and my worst fears about the project have come true. My lug nuts are on way too tight and it's near impossible to get them off without giving myself a hernia.
Does anyone have any advice on how to make the process easier? I was thinking that I could use some WD-40 to help loosen things up a bit, but I'm not too sure how safe it will be on my wheels.
If anyone has run into this same problem and has some helpful advice, I'd appreciate it. Thank you.
12-17-04, 01:13
Dr. Jan Itor
ZaneO is offline
Find a long breaker bar.
WD-40 will probably be okay as long as you avoid the brakes and thoroughly wash the wheels when finished (will need to be protected again also).
Originally Posted by David Fermani
I don't care if Sal dropped a deuce in my package
12-17-04, 01:26
VictoryRed is offline
Counter clockwise  , stand on it, WD-40=Rust
Recovering public school student.
12-17-04, 01:35
Super Moderator
JDookie is offline
First, use a penetrating lubricant like Liquid Wrench over the WD40 and second use an impact. If you don't have access to an impact a longer breaker bar is all you can do. Sometimes (I know this sounds weird) trying to tighten them just a hair will release the nut and allow you to remove them easier. Just remember to let the penetrating lubricant sit on there for a few minutes before you go wrenching on them.
12-17-04, 02:25
Bill D is offline
Kano Labs' Kroil is like WD-40 on steroids.  A few years ago I had to use this and the help of a 265 lb friend using a spinner wrench with a piece of pipe placed over it to get the wheels off! Damn tire shop!
12-17-04, 03:01
Got secondaries?
Aurora40 is offline
You DON'T WANT WD-40 on your wheel studs! It's on tight due to torque probably, not due to rust or binding. It'll be hard to clean the wheel studs completely after you spray WD-40 on them. Do you have a breaker bar? That will really help.
Make sure you check the wheel studs for any stress lines or anything. And try to make sure that never happens again. Three wheel studs snapped on the Regal, shearing the other two lugs and separating the wheel from the car. I suspect it was due to years of overtightening, though I can't be certain...
12-17-04, 05:00
Dr. Jan Itor
ZaneO is offline
When you put those lugs back on, make sure they are around 100 lb. ft.
12-17-04, 05:07
I love curves
kartoon is offline
I second the breaker bar idea. If you don't have an impact wrench, a long bar will save you in many situations.
I got mine from Harbor Freight for a few dollars.
When you tighten the wheels use a torque wrench. For my car the recommended torque is 80 ft-lbs.
12-17-04, 06:29
Carnauba for Life!
JM19 is offline
Unfortunately, I tried everything I could that was reasonable and they still did not come off. I suspect that the last place that rotated my tires must have put them on too tight with a machine.
I am actually getting quite fed up with the way many places tighten things on my vehicle. I had a problem two weeks ago before I was about to change my oil in that the drain plug was put on too tight also. It was really frustrating as I had to take my car to a local service station and they had to loosen it for me.
I was thinking of taking my car to a garage around here and seeing if they can help loosen them for me. It's somewhat disappointing as I was looking forward to rotating my tires on my own. However, I'd rather have someone with some expertise remove the lugs first before I hurt myself.
Jeff
12-17-04, 06:47
HRP is offline
I always tell the manager to hand torque the lug bolts and that I will check them to make sure I can remove them before I leave the shop. That usually works, but be sure you actually check them (at least 1 on each wheel). I only had to make them remove them and then put them back with a torque wrench once.
"Show Me something more beautiful than a beautiful woman..." Vargas
12-17-04, 06:54
Turtle Wax User
LouisanaJeeper is offline
anti seize
some like it, some dont, i do
Black Mustang GT
12-17-04, 07:07
kempie is offline
How about this time you take it to a shop that will use a torque wrench to tighten tham after they rotate them. Then next time you can do it..after you get a torque wrench.
Over tightening can cause warped rotors as well as broken bones.
