Old 11-25-04, 01:49   #1 (permalink)
Rubbin' it all day long
armoredsaint's Avatar
armoredsaint is offline
Talking Getting a new 2.5 Car Garage Built, your ideas?
I want to keep it semi-simple this time around and not spend big bucks like a lift for example, because my neighborhood ASSociation will not allow it and a garage drain is prohibited too. I have so far is hot and cold water outlets, telephone jacks, 7 electrical outlets, 6 overhead lighting fixtures / 2 metal hilades, stereo speaker wiring, ethernet connections, iDrive garage opener and what else? I will do the shelving and cabinets later. Maybe a heating system since I do live in Ohio?
Thanks!
2006 BMW 330i Titanium Silver / 2009 BMW 335i coupe M-Sport Black Sapphire Metallic
Old 11-25-04, 02:53   #2 (permalink)
Too Old to be Doing This
az57chevy's Avatar
az57chevy is offline
If you have soft water conditioner plumb a line into the garage.
It is not so much how many duplex plugs you have but how many amps. Have you considered an air compressor? Perhaps a cable outlet as well?
Old 11-25-04, 05:50   #3 (permalink)
Pondscum's Avatar
Pondscum is offline
Are the hot and cold outlets for a sink? I have a deepwell sink in my garage and it's invaluable. Make sure you get a sprayhead on the sink.
You might consider doing one wall in pegboard.
If you plan on heating the garage at some point, you'll want insulated walls and garage doors.
Consider installing a good sized air compressor in a fixed/semi fixed location and plumbing fixed air lines to strategic points around the garage. You can do a good sized shop-vac the same way.
For the electrical, you should have two 20 amp circuits for the outlets. Every other outlet should be on the same circuit so in the unlikely event you would need more than 20 amps at the same time, you would have it available all around the garage. Nothing else should be on the circuits with the outlets. All outlets you intend to use tools on should be GFCI protected.
Since you have so many lights, you may want to have them on two different switches. That way you don't have everything on when you don't need as much light.
Ceiling fans and/or an exhaust fan would be nice in the summer.
Next to both of my garage door openers, I have a retractable power cord mounted to the ceiling. This allows me to use my PC all around my vehicle without messing with extension cords.
Old 11-25-04, 06:02   #4 (permalink)
autoracer1 is offline
http://www.ultimategarage.com/UltGar2.htm
I'm sorry for posting it, because now it's going to make you spend more than you likely were before :P
Old 11-25-04, 06:22   #5 (permalink)
kgb
kgb's Avatar
kgb is offline
Contact: Send a message via Yahoo to kgb
More lights and outlets! LOL and make sure that you have a seperate breaker box for the garage IN the garage. Too many people just tap into the house and leave it like that. If a breaker blows you have to go downstairs or wherever your box is to fix. Oh and 220V would be a major plus!
Wax and polish sniffer.
Old 11-25-04, 07:28   #6 (permalink)
OI812 is offline
Is the garage attached or unattached? I would put a sub-panel in the garage. One with at least 20 or 30 spaces for breakers. I would make sure the sub-panel is feed by at least 60 amps, but more preferably a 100 amp breaker.
On the hose bibbs I will post the links to the one's I like.
The one I have on my house is a Woodford Model 22
The one I'm going to be installing on my house is a Woodford Model 67
If you need pricing let me know, I may be able to help.
Old 11-25-04, 07:40   #7 (permalink)
Thanks for the replies, the hot and cold is for the hose and it's in a "mixer" thingy, I will have another hot and cold plastic tub for washing parts and stuff too. The garage will be attached to the back of the house, the separate fuse panel sounds like a good idea too, along with a compressor! More money...
Old 11-25-04, 07:40   #8 (permalink)
HRP
HRP is offline
Exterior lights, but add an additional switch in the bedroom so you can turn it off when you forget it without having to wander the house or go into the garage to get those outside lights off. All of our outside floods are also switched in the bedroom as well as at the appropriate doors; and it is great!!!
"Show Me something more beautiful than a beautiful woman..." Vargas
Old 11-26-04, 07:11   #9 (permalink)
OI812 is offline
Oh yea make sure the cold to the hose bibb is cold SOFT. Or put in a seperate one that is cold hard, So that you can have all soft water on the mixing valve.
Old 11-26-04, 11:57   #10 (permalink)
TDMAN is offline
Nice. Next time I get my $500,000 paycheck, I'll start building it.
Old 11-26-04, 12:51   #11 (permalink)
Lost Pup is offline
I have a 2 1/2 Insulated Garage Door and it clearly reduces heating/cooling costs but also noise transmission to the house. Nice as I find I spend mostly evening and late night hours in the garage.
Old 11-26-04, 01:40   #12 (permalink)
What I really want to do is paint the floor, but how long should want until the concrete is fully cured? I read about Rustoleum, but the durability was questionable.
