11-22-04, 10:26
Carnauba for Life!
JM19 is offline
Antifreeze/Coolant Flush and Refill
Does anyone know of a website that will give clear, understandable directions of how to safely flush and refill the antifreeze/coolant in my car?
11-22-04, 10:35
Dr. Jan Itor
ZaneO is offline
What do you drive?
Originally Posted by David Fermani
I don't care if Sal dropped a deuce in my package
11-22-04, 10:36
Bill D is offline
Perhaps http://www.bobistheoilguy.com I routinely flush four cars a year following very slight variances per car. It can be a long process especially when attempting to get all your flush water as clear as possible.
11-22-04, 11:45
Carnauba for Life!
JM19 is offline
Originally posted by ZaneO
What do you drive?
I drive a '99 Mitsubishi Eclipse GS (non-turbo).
11-22-04, 11:57
Bill D is offline
A Haynes and/or Chilton manual, if available for that car, just might show enough detail to instruct you how to do it
11-22-04, 12:15
hadboosttroy is offline
yep either of those manuals, or seeing that you drive an eclipse, i am sure there is a forum for that car with tech articles.
11-22-04, 01:18
Bill D is offline
I go beyond that by after draining the old antifreeze, filling the radiator with water , turning the car on, heat on max, running it, stop when upper radiator hose is warm, drain the water, repeat until you can get the drain water reasonably clear. Then follow the procedure for refilling with new antifreeze.
On some vehicles there may be a bleeder scew on the engine block ( The Honda Accord and Nissan Maxima I do have it) so be sure to open that up while refilling, then close in the end. Hope this can add to what you found.
11-22-04, 01:34
Lowejackson is offline
Yup, that is the way I do it. As I recall, this used to be the Mercedes recommended route as well.
11-22-04, 02:30
Carnauba for Life!
JM19 is offline
If I cannot gain access to the bleeder screw is it alright just to leave it closed?
Also, do you fill the radiator with a gallon of antifreeze and then top off the rest with just clear water? (By the way, my radiator holds 7.4 quarts)
After the radiator is filled, do you then pour diluted or straight antifreeze into the reservoir?
Sorry if these questions are so basic, but this will be my first attempt and I'd like everything to be as smooth as possible.
11-22-04, 03:27
Bill D is offline
At least on the cars I do, the bleeder screw ought to be fairly accessible.
Do make sure you use the correct antifreeze or you will have a serious problem. Consult your owners manual or delaer to verify.
For me, I can get away easy, I just buy prediluted Prestone in the gold jug and add. I used to get the one in the yellow jug before the premixed came out.
If you are going to get pure, undiluted antifreeze , mix it 50/50 with distilled water in a container beforehand and then add in the end.
Remember, that will be 7.4 qts of the 50/50 mix NOT pure antifreeze
11-22-04, 03:40
Carnauba for Life!
JM19 is offline
I have seen the prediluted Prestone advertised. I think for the sake of convenience I might just go with that type. Do you find it performs just as well as undiluted antifreeze? Also, if I did decide to purchase it, would I use the regular fill amount in my radiator (up to the top of the fill spout) and then top off the reservoir as usual?
