10-28-04, 06:07
AutoNova is offline
Rustoleum Garage Floor Epoxy
"I think my blood is a Carnauba Prototype"
10-28-04, 07:03
Red98gt is offline
I put in down about a month ago. Was really anal about cleaning the floor! Really like it so far. Only gripe would be I wish I had used 3 gallons instead of the 2 recommended. Some areas look a little thin, not as glossy. If I did in again I would put down 2 without the flecks then top it with a 3rd and add the flecks then. Other than that it really improved the looks of my garage.
07 Nissan Titan
02 GMC Envoy
10-28-04, 07:12
AutoNova is offline
I agree with you 100%. If I could find the flakes I would put down another coat and add them again. It is hard to judge the 1st time, I thought I wouldn't have enough paint but I had more left over than I thought and couldn't do anything with it. I almost wonder if you can buy those same items with out the kit? I saw they also have a 2.5 car garage kit but is $100.
10-28-04, 07:25
Beercan31 is offline
I like the look of the flake in the finish
QUESTION
is the floor slippery when wet?
I did a small section in my shop and used "Steel Guard" gray with hardener and corse sand, I don't slip and slide but it's a PIA to keep and get clean.
Rich
I'm going as fast as I can, You want to go faster GET OUT and PUSH.
10-28-04, 10:15
Red98gt is offline
Yes, that's the main problem. You start out too thin wondering if you will have enough! I had a bunch of flecks left over, when I can talk the wife into it I am going to put another coat on it. Was even thinking about just a floor epoxy and not the whole kit.
Beercan31 - No, it is not slippery with the flecks, you can feel them sitting on the top of the paint. Not rough but gives just enough grip.
So far they stay stuck even with the weight of my Envoy turning on them. Found out a squeege doesn't work worth a darn when trying to clean it. Good old mop works great.......
07 Nissan Titan
02 GMC Envoy
10-28-04, 10:19
Peter Crowl is offline
Nice Job!
Having a finished garage floor is the mark of success
Seriously...it looks great and I'm sure you'll be very glad you did it.
I found the hardest part of the flooring job was emptying out the darn garage so I could see the floor!
Peter..in Denver
10-29-04, 06:06
AutoNova is offline
What can you buy that is the same as what comes in the kit but where you don't have to buy the kit? I bet the flakes you could get at any arts and crafts store. I need to ask the people at Home Depot what the kit contains and see if I can buy it cheaper that way and put downa 2nd coat.
Red89GT,
How long did you let yours dry before putting a car on it?
10-29-04, 06:54
Edwa is offline
I used this kit on my garage about 2 years ago. I did not use the flakes. My garage is 24.5' x 24.5' and I ended up using 3 gallons.
Autonova,
There were three different times, 12 hours to walk on it, 24 to place items on it and 72 hours to drive on it.
Without the flakes it is very slippery when wet. I just had a feeling that the flakes would wear out or come out quickly and would rather deal with the slickness when wet.
Its held up very well. The shine does not last very long due to vehicles pulling in and out, walking/scuffing but will still make sweeping a breeze and wiping oil spills a piece of cake.
The key to this or any kit is in the prep....sound familiar. I powerwashed, used a concrete cleaner and worked it in good with a hard bristel broom, powerwash, cleaner again, powerwash and powerwash.
10-29-04, 07:07
AutoNova is offline
Autonova,
Did you buy 2 kits, my kit only came with 1 gallon?
10-29-04, 09:25
Edwa is offline
Two kits covered my 24.5' x 24.5' with a little left over. For the hell of it....I came back a week after put down one more kit over the entire area. This last gallon spread real easy over the cured first application.
10-29-04, 10:57
Red98gt is offline
AutoNova, I waited a full week before I drove on it. Was tough leaving the cars out but the instructions said a week so I waited that long. Stayed off it for 24 hours, moved stuff back in after 72.
I did use a different paint on the 6 inch stemwalls. It was a concrete "stain" that Lowes carried. Was a little lighter grey. Actually looked like paint but was REAL watery! Soaked into the pits and stuff and really finished off the edges. I also painted the walls white so the garage is really bright. I still need to get some pictures taken......
07 Nissan Titan
02 GMC Envoy
10-31-04, 01:20
AutoNova is offline
All Done with project
