Hey guys,
I just wanted to update you on what I've been doing since I posted this thread.
I decided to use the 2 car that's on the other side of our house. It's deeper and wider than a normal 2 car so everything fits in really nicely. Plus there's a closet that's flush with the wall as you'll see in the pics.
For the floor, I put down the Behr garage floor coating system. It included cleaner/degreaser, acid etch, bonding primer, and the epoxy paint. 2 weekends was all it took, but it only took a day to do the cleaner through the primer. The next day I laid down the base coat and came back a week later to put on a 2nd coat. I really like the flooring, but I think the color's just a bit too light
I've included pics of when the 2nd coat was dry. Since then, I've hung some cool car and truck pictures and reorganized the whole closet. The floor paint is starting to come off where it got a little thin, so what I plan to do is get some sort of a medium gray and repaint the floor, then take the same color code, get some enamel wall paint, and paint right over all that dark and disgusting wood paneling. I fell it'll create a uniform look and will bring the garage into this decade
. If I can find good ones, big flourescent lights will take place of the dim globes on either side of the garage door opener. The garage gets a TON of natural light, so that helps too.
So check out the pics, enjoy, feel free to critique, and leave suggestions if you have any!
Thanks
