06-17-04, 07:00
MSOsr is offline
Good air wrench?
Any opinions as to a good (inexpensive?) air wrench just for removing and putting back on wheels? (maybe 80 lb.ft. of torque)
Preferrably one that will work well with 4.2 CFM @ 90psi or 5.6 CFM @ 40psi.
Thanks.
06-17-04, 07:09
wifehatescar is offline
I run this:
http://www.harborfreight.com/cpi/cta...temnumber=2623
off my small 3hp compressor, it works great! You need a powerful one to take off wheels (especially if the tire place put the wheels on too tight, etc)
I have a smaller Campbell Hausfeld (whatever) I can sell you for $20 (bought it for $40 I think, haven't used it much). It supposidly makes 250ftlb but it was too weak for my taste.
"This is not the USA. This is Autopia." - Mmmph
06-17-04, 09:01
MSOsr is offline
How do you use it to put the wheels back on if they only require 80 ft.lbs. and the wrench is 175, 200, 225 or 250 ft.lbs.? Isn't there a danger of overtightening and/or wrenching the lugs off?
06-17-04, 11:04
Never tighten lugs with the gun! It's only used for removal of lugs, bolts, etc.
PS - the HF gun has a 5 position power switch to vary the power. I usually LIGHTLY spin the lugs back on with the gun at the lowest power, then finish with a torque wrench at 90ftlb.
06-18-04, 06:03
MSOsr is offline
Thanks, guys!
06-18-04, 01:57
I didn't know I counted as more than 1 person
06-21-04, 02:27
kentd98 is offline
i second the recommendation
The earthquake seems to be a decent gun. i have used it for wheels/tires and also for suspension work (loosening bolts/nuts).
About $100 cheaper than an equivalent 'brand name' gun.
I got mine on sale for $72.99.
Kent
06-21-04, 02:35
kentd98 is offline
Kent
06-21-04, 02:43
GearHead_1 is offline
Great question and all too often over looked. The simple answer is that you shouldn't torque your lug nuts with an air gun. You may choose to run the nuts to the wheel with the gun but use a torque wrench for tightening the nuts. An air wrench is great for taking lug nuts off but not the the correct tool for putting them back on. Torque the nuts in sequence or at least in a star pattern. Over tightening can cause several problems (stripped studs, damaged wheels, warped rotors), not many fingers can guage the extent of an air wrenches tightening abilites. By the way their are a lot of vehicles on the road that require significantly more than say 80 ft./lbs. of torque.
No Applause, Just Throw Money!
06-21-04, 09:29
Spotty-Dog is offline
I agree all the way
As they say, Check your Owners Manual. My old X5 wanted 94 ft/lbs.
2002 MB CLK55Cab | 2007 ML63
Garage:
07-03-04, 11:34
Andrew ACR 2 is offline
This is what I do for lug nut removal and torque. I use a sears torque wrench and a Dewalt 14.4 volt cordless impact wrench that has around 100 lbs of torque. This is the best tool I have ever brought. I have a 2002 ACR Neon ,in which i autocross and drag race. I am always removing the wheels. I torque to 90 lbs.
07-27-04, 10:15
higB_0x02 is offline
Re: i second the recommendation
Kent
I just got mine in the mail yesterday. I was a bit surprised by the weight of it. (wow its heavy)
I didnt have time to really take a look at it.. but the tip didnt seem to have the little ball bearing bee-bee to hold on the socket. Do I need something extra?
