Old 02-28-04, 01:42   #1 (permalink)
ReShiner
KenSilver's Avatar
KenSilver is offline
Yet another question about best floors
Excitement!
I've just figured out how to extend my 2 car garage into a 4 car by extending it forwards to the street. This will give me inline parking with the daily drivers in front of the two garage queens. (We're 4 cars for 2 people!)
So now I'm looking at ways to treat the floor, again.
In the past I've used Bondall Industrial /Garage floor paint on my existing concrete, but it lasted a year before lifting on hot tires. Now water spillage has increased the lifting. I did everything right, but as I read on this forum, paint of any kind doesn't last long, and that's a fact.
The thing that bugged me was the hot tire browning and dirt I couldn't scrub off. It only took a month or two to start looking shabby.
So now I'm thinking of tiles.
I'm not thinking of the fancy Italian jobs... I don't have time, expertise or money to buy and have these laid.
But instead I thought of laying self-adhesive tiles - the plastic or linoleum ones that you get for bathroom or kitchen.
Has anyone used these? How do they stand up to heat and weight?
This way I can lay a black & white pattern down, and if a tile or two gets damaged or dirty, just rip the offenders up and replace them with new ones? That seems to me to be a cheap and practical way for an attractive floor, and means that you don't spend a week painting the floor and waiting for it to dry.
It seems to be the ideal answer so far. What am I missing?
<a href="http://community.webshots.com/user/silverken" target="_blank"><b>Ken's Garage</b></a><br />1993 Mercedes SL500, 1999 Mercedes SLK230, 1999 Lexus LX470, 1999 Suzuki Grand Vitara. Finish detailing, then start all over again...
Old 02-28-04, 01:47   #2 (permalink)
ReShiner
KenSilver's Avatar
I could be wrong, but the splendid Vette garage at http://temp.corvetteforum.net/c5/richs7/index2.shtml looks like it has plastic tiles rather than ceramic.
Anyone know for sure?
Old 02-29-04, 02:31   #3 (permalink)
ReShiner
KenSilver's Avatar
Problem solved...
I found the answer by emailing the Corvette garage owner, Rich Lagasse, and he was exceptionally friendly and helpful in his replies.
Nice to share an interest with such a enthusiast.
The tiles in the photos from the link in my earlier post are vinyl, and Rich allowed me to reprint his following replies to me giving some detailed information about them:
"We built the garage over ten years ago and the tiles were installed then. They are Armstrong Commercial grade vinyl tiles and have held up remarkably well even through some abuse. :-)) The hot tires have not been a problem.
Someone once told me what the PSI pressure was of a hot tire as it is cooling and it was amazing. I did have one type of tire (Goodyear Run Flat), that must use a weird rubber compound, and it did leave a tread mark where the car stood. No other tire has left a mark so it must be unique to that tire.
A few thoughts about installation and maintenance:
- When installing them the floor should cleaned well, any uneven spots leveled and a sealer applied for moisture. Then, we used the recommended tile adhesive when laying them.
- After the adhesive had set I applied three coats of floor sealer followed by three of a heavy duty floor wax. These were made by Zip but I'm sure there are other brands that will work as well.
- Keeping it clean under normal circumstances just takes the old mop or one of those "Swiffer" cleaner cloths. Of course, I have had to use something stronger to remove some paint overspray or to remove oil or grease. Fantastik or household cleaner will work on most spots.
- The colors of the main body of tiles is a mixture with an off-white background. That works well for the main areas but I did find that that color was more time consuming to keep clean in the path where the tires run. I decided to do the contrasting blue in that area and it helps to outline the main parking area as well.
- I don't know where you live but here in Connecticut we have a lot of snow and I do protect the floor from the snow and sand/salt we get in the winter. I use "Car Pads" and those have worked well for that purpose.
- One good thing about tiles is that you can replace an individual tile if one is damaged. I bought four extra boxes for that purpose to keep the same job lot.
There are many different types of flooring now and vinyl tile is one of the better ones as long as it is laid properly and the usual maintenance is performed. I had tried epoxy paint many years ago but found that it would wear where the cars were driven. Some of the choices in floor coverings can be rather expensive (such as Race Deck or the Griots tiles) but I've found the vinyl to work well and be reasonable from a cost standpoint. Some folks have used a checker-board black & white floor and that looks nice but can be a little busy."
I'm sure Rich won't mind if I also pass along his website address - it has a lot of interesting stuff: http://www.corvetteforum.net/c5/richs7/
Old 02-29-04, 05:11   #4 (permalink)
jermar is offline
After years of failed epoxy paints, I went with www.racedeck.com tiles. For me it was the best way to go.
Old 03-11-04, 11:51   #5 (permalink)
MBZ 500E is offline
jermar,
can you post pictures of the racedeck installed? Also would love to hear a detailed description of how they're holding up. I've been looking at different floor coverings for a while and I'm thinking of going Racedeck instead of a high end epoxy. My biggest concern is how the tiles hold up to a car jack or jack stand with pinpointed pressure. Your thoughts would be appreciated.
Ken,
Keep us posted on the project and post pics!
Afshin
90 Porsche 928 GT - Marine Blue
09 MazdaSpeed3 - Metropolitan Gray Mica
04 Honda Pilot - Silver
Old 03-11-04, 02:06   #6 (permalink)
keperkey is offline
How much does racedeck cost per foot?
Old 03-11-04, 02:08   #7 (permalink)
MBZ 500E is offline
Prices I've seen range from $4 - $5 Per Square Foot
Afshin
Old 03-11-04, 09:22   #8 (permalink)
ooooooh shiny things
flynfrog's Avatar
flynfrog is offline
Contact: Send a message via AIM to flynfrog Send a message via Yahoo to flynfrog
the armstorng or concgolium tiles are the way to go they will last forever they may crack but they will still stay in place make sure they use a good glue that wont be bothered by most chemicals and the tiles cost the installer about a buck a tile if i rember corectly
Old 03-12-04, 05:28   #9 (permalink)
keperkey is offline
They sure must be proud of that stuff. My garage would cost between $2500 and $3000.
Guess I will wait until I build me dream garage.
Old 03-12-04, 01:22   #10 (permalink)
jermar is offline
Ken: Race deck has held up very well. You can use a floor jack, no problem. I also have three leg jack stands. I use a scrap of quarter inch plywood under them. I cut the tiles that meet two walls with a hand saw. The other two walls get a black transition edge. Only down side, it's another floor to mop. I did my two car garage for about $1200.00. This is a "floating " design. No glue. The tiles snap together with a little help from a rubber hammer, and you leave 1/4 inch gap at the walls for expansion. It took me a day & a half with lots of breaks. I did it in blue & gray checker pattern. Sorry, no pics.
Old 03-16-04, 08:34   #11 (permalink)
Tiger is offline
It may be worth looking at stamped concrete as an alternative. After a lot of research on garage flooring, I recently went this route for my new garage.The choices of patterns and colors are only limited by your imagination, the cost is about the same as Racedeck tiles,the sealant used after the concrete is stamped will not wear off from warm tires etc., and,IMO, the appearance is much better than most reasonably priced tile alternatives.
Old 03-16-04, 12:39   #12 (permalink)
ReShiner
KenSilver's Avatar
jermar,
Good idea. My problem is sourcing it. We're at the bottom of the world here, and I just don't have the options as you would in US.
Tiger,
I've seen a stamped floor in my "Ultimate Garages" book and agree it has every advantage. But I'd have to tear up my existing concrete floor to have it laid, and I'm not sure I want to do that.
