Old 01-07-04, 12:57   #1 (permalink)
pringle is offline
bleeding brakes
any suggestions for doing it single handed?
i.e: speed bleeders, vacuum pumps, pressure pumps, etc..
Anyone have any problems with leaving those speed bleeders on? Are pressure + vacuum pumps a better bet since they can be used on multiple cars? Any suggestions on the type/brand?
tnx
2002 Silver Accord EX (Klasse'd)
Old 01-07-04, 01:10   #2 (permalink)
Mmmmmm, forbidden polish
gnahc79's Avatar
gnahc79 is offline
speedbleeder.com
speedbleeders are replacements and I've had no problems with them on my motorcycle. If you go the bleeder route, get the hose & bag while you're at it. Keeps everything clean and easy for proper disposal.
edit: the mityvac isn't super pricey, doh. Some ppl have some problems with the vacuum pump, though (air bubbles).
Old 01-07-04, 01:32   #3 (permalink)
medic is offline
you can get a 1 man bleader kit at most auto stores - works fine just takes time since you need to keep stopping and filling the resivour to avoid bubbles
Old 01-07-04, 02:43   #4 (permalink)
tomstin's Avatar
tomstin is offline
Works like a champ! http://www.motiveproducts.com/
Old 01-07-04, 03:26   #5 (permalink)
BakesV8 is offline
When I got my new brakes, I couldn't get the speed bleeders to thread properly (I think I got the wrong ones), but after doing the two person coordinated effort job, I would say speed bleeders are the way to go. Good luck with it.
2004 Honda S2000
Suzuka Blue Metallic
Blue soft top
Old 01-07-04, 03:35   #6 (permalink)
Senior Moderator
Brad B.'s Avatar
Brad B. is offline
I have the Motive Bleeder and like it as well. I bleed my brakes a LOT in the summer due to track events.
Old 01-07-04, 04:18   #7 (permalink)
gnahc79's Avatar
gnahc79 is offline
oh yeah, keep your OEM bleeders in case you want to put in new brake lines. Speedbleeders don't work on a dry line, so you need to use the OEM bleeder to fill the line ~90% and then swap in the speedbleeders.
Old 01-07-04, 04:48   #8 (permalink)
member from the old board
tom p.'s Avatar
tom p. is online now
MOTIVE
...just make sure they have an adapter for your car.
Old 01-08-04, 06:36   #9 (permalink)
Senior Moderator
Brad B.'s Avatar
Brad B. is offline
Oh, great point. Makes sense. Thanks.
Old 01-08-04, 08:08   #10 (permalink)
wifehatescar's Avatar
wifehatescar is offline
I have a general question on bleeding while we're at it.
I bleed the brakes by myself by opening the bleed screw with a clear tube on it funneled and submerged into a bottle with a small amount of clean brake fluid already in it. I keep the bleed screw open the entire time.
I then alternate between pumping the pedal and filling the MC.
It seems to work fine, although the manual says to push the pedal down and hold it there and close the bleeder after say 10 pumps or so.
My theory is however, even if the bleed valve sucks a small amount of fluid back up, it's still just brake fluid, not air. Any comments?
Again, I assume since my fluid runs clear at the end with no visible bubbles, my method is ok.
It's just weird to me that no one else recommends this because to me, it's like $1 to buy the tube and have a small plastic bottle, and it's really easy too.
"This is not the USA. This is Autopia." - Mmmph
Old 01-08-04, 09:11   #11 (permalink)
rek
NOT, A Brick in the WALL!
rek is offline
http://www.bmw-m.net/TechProc/bleeder.htm This looks like it might work. General Question: I think it is recommended to tighten the screw after several pumps, to avoid air entering the system. There IS a slight "Air Gap" between the bleeder screw threads and the wheel cylinder/caliper tapped hole, once it is loosened. Wrapping the BS with teflon tape, or a small dab of silicone grease, will seal the gap if you're bleeding the system with the brake pedal. IMO. "Power" bleeding is the way to go IF the master cylinder is clean and has clean fluid in it,(Don't want to flush dirt INTO the system from the master cylinder). I have "Back-flushed" , starting at the farthest wheel from the MC, with a mity-vac, then power bleeding, to complete the job, with excellent results.
Old 01-08-04, 09:23   #12 (permalink)
gnahc79's Avatar
gnahc79 is offline
I've heard of ppl doing this too, it makes sense to me:
- do the pump, close, pump close thing until fluid fills the hose and goes into the bottle.
- keep the bleeder open pump away
I might try it out this week when I put in my Galfer steel lines.
rek, I thought the bleeder screw needs to be tightened after each pump
