Old 01-06-04, 07:00   #1 (permalink)
jw
jw is offline
Griots Vs Pela Oil Extractor?
Is there a difference between the pela 650 and the griots oil exctractor. I can't decide between the two. The griots one looks like it's $20 bucks cheaper than the pela.
Thanks
Old 01-06-04, 08:34   #2 (permalink)
Bill D's Avatar
Bill D is offline
I have a pela, I'm not sure what the model number is, but I think it is the griots equivalant. A few years back Consumer reports tested the griots and the pela, because the pela is cheaper I got that one.I also recently purchased editional hoses for the extractor directly from pela, good service
my product collection
My Detailing Credo
Old 01-06-04, 09:08   #3 (permalink)
GearHead_1's Avatar
GearHead_1 is offline
Contact: Send a message via AIM to GearHead_1
Here's one worthy of consideration. They make a pneumatic version of this also.
http://www.thetoolwarehouse.net/shop/MIT-7201.html
MityVac
Fluid Evacuator Plus
Order# MIT7201
$97.35 List Price
$56.05 On Sale!
[Add to Cart] [View Cart]
• No power required, creates vacuum and pressure
• Ability to evacuate and dispense most automotive liquids and chemicals.
• External pump design
• Large capacity 8.8 liter fluid resevoir
• Automatic flow control prevents overfilling
• Pressure relief valve for safety
• Durable polyethylene construction will not rust or corrode
• Dip stick tube included for engine oil removal
No Applause, Just Throw Money!
Old 01-07-04, 05:49   #4 (permalink)
member from the old board
tom p.'s Avatar
tom p. is offline
Pela has a few different models. I suspect Pela is the OEM for Griot's unit.
Noteworty: MityVac has a large unit similar to the Pela. it's a multi-purpose config and can be used for other tasks. I would strongly recommend checking it out before buying anything else as it can perform other routine jobs we all enjoy.
Try to get a unit made from clear/translucent plastic so you can see how much oil you have actually pulled out. Otherwise, you don't know if you've done a good job. I think the Pela has gradient markings on the canister to indicated fluid amount.
Old 01-07-04, 06:53   #5 (permalink)
rjstaaf's Avatar
rjstaaf is online now
Has anyone used either of these units for extracting brake fluid? It looks like it would be great for flushing the brake system.
Bob
1997 Honda VFR750F
Old 01-07-04, 06:59   #6 (permalink)
tom p.'s Avatar
tom p. is offline
the MityVac will do both jobs. that's why I mentioned it.
Old 01-07-04, 07:03   #7 (permalink)
rjstaaf's Avatar
Have you used any of these units for flushing the brake system? I was hoping for input from someone who has actually used any of these units for that purpose.
Bob
1997 Honda VFR750F
Old 01-07-04, 07:43   #8 (permalink)
TOGWT is offline
Contact: Send a message via ICQ to TOGWT
Quote: Griots Vs Pela Oil Extractor?
~One man’s opinion, observation~
I use a Griot’s Brake Fluid Extractor (P/T # 55615) as it ‘exchanges’ brake fluid (includes a reservoir bottle for new fluid)
I also own the Hand Pump Oil/Liquid Extractor and use it for oil, coolant/anti freeze solution, etc. I prefer the other extractor for brake fluids, as it’s foolproof (you have my word on that, see justa…) J
~Hope this helps~
Experience unshared; is knowledge wasted…/
justadumbarchitect * so i question everything*
Old 01-07-04, 08:27   #9 (permalink)
tom p.'s Avatar
tom p. is offline
I have all separate units for the different jobs. If the MityVac unit was available earlier, I probably would have purchased that unit versus the different units I have ended up with.
I really like the MOTIVE pressure bleeder ($45) for our VWs and other euro cars. You have to make sure they have an appropriate adapter for your brake reservoir. Many cars with ABS systems require a pressure bleeder to properly bleed/flush.
I also have the Griot's Garage vacuum bleeder which gets connected to your air compressor and sucks fluid out by means of a venturi...it works quite well but was big $$.
