10-12-02, 12:18
Hearse Driver :)
Redcar GUY is offline
Looks like an ok Idea.... but how does a creeper work on that stuff? also If 8X20 is $130 it would be like $600 to do my garage  I like the way it looks though
Bill 97 Camaro SS #1422
10-12-02, 04:42
Frederf is offline
Looks like a good product, but I'd go broke on 303 though.
The relentless persuit of "eh, close enough."
10-12-02, 12:48
PAW is offline
HEY! Who you calling a creeper?!?!  The highest level of mechanical work I do is an oil change. Actually I haven't done one of those in years. I'm skinny but still not skinny enough to have fit under by '01 Legend. My TL is higher and the wife's Pathfinder is even higher. I'll probably start doing oil changes again. Once I get past 7,000 to 10,000 miles and I'm ready to switch to synethic oil. I'm think about changing the shocks my the Pathfinder. They have worn and it ride way to much like a truck for my tastes.
303. Nah! just drag it outside, squirt it with some 409, scrub with a broom and hose it off. That is when our water restrictions are lifted. I can't even wash the cars in the driveway.  Unless it snows. I used Protect-Alls Quick and Easy wash. It did a good job but I notices a few minor swirls. I'll change my technique next time.
I just want the pads to reduce the amount of dirt that gets tracked in the house. Also, to control the water from snow melt. Redcar Guy's floor looks nice enough to eat off of. That's a little more that I want to do. Though I do admire it.
10-12-02, 01:06
Searching for the facts
BradE is offline
I have one and really like it. If you buy one take a buddy with you, they are heavy!
My garage floor has epoxy paint but I still use one of these. It keeps the mud, dirt and all the other crap off the floor and I don't have to clean it so often. You can't use any type of jackstands or floorjacks on it though.
Overall I would say it's worth the $$$$, especially if you can't afford to have your floor done with epoxy.
10-12-02, 01:15
Hearse Driver :)
 no can do, I have to be able to use the jack and stands...
10-12-02, 02:40
Shiny Lil Detlr is offline
as easy as it is to roll up, just move the car off the pad, roll it up, move the car back in the garage and do your work.... then you can just move the car again, unroll, and park after you're done with your work.....
10-12-02, 03:14
Frederf is offline
I bet you can put "hard, sacrificial pads" under your jacks and stnads.
10-12-02, 07:23
BradE is offline
Yep. Scrap plywood works pretty well.
10-12-02, 08:29
PAW is offline
Damaging Pad
So, the jack or floor stands would damage the pad? Does the plywood under them distribute the weight enough to protect it? Or is it the edges of the jack/stands that cuts into the material?
10-13-02, 10:37
BradE is offline
The plywood works well for me and I have not had any problems.
The thing is not going to stay pretty for long, hot tires will leave tracks in it. Better the mat than the expensive floor.
10-13-02, 11:33
PAW is offline
ShowroomLincoln
How do the hot tires leave tracks? Do you see tire imprints or the the ribs get flatten or what? How long have you had your pads? How are they holding up and hold long to you guess they will last? TIA for you input. I don't want to blow a couple hundred bucks on something that only lasts a year.
