Page 1 of 2 12 LastLast
Results 1 to 12 of 14
  1. #1
    Garage Door Insulation
    Join Date
    Jul 2007
    Posts
    808
    I am working on doing some improvements on the new garage, and one of them I am considering is insulating the garage door. The current door is a little bit older model before insulated doors were the usual standard. I used a laser thermometer and the metal door from the inside of the garage was reading about the same temperature as outside, so its definitely allowing the cold air through.
    I was looking at Home Depot and came across these DIY garage door insualtion pannels
    Garage Door Insulation Kit-500824 at The Home Depot
    To do a 2 car garage, looks like I will need two of these kits. So I'll have around $120 tied up in this if I go this route. Has anyone used a similar type of insulation on their garage doors on here? I was wondering if these will make a noticeable improvement before getting them
  2. #2
    Re: Garage Door Insulation
    Join Date
    May 2007
    Location
    Wakefield MA
    Posts
    359
    I installed one of those Home Depot kits. Last night it was about 25 degrees out. I put an IR thermometer on the outside of the door and it was around 27. I did the same on the inside of the door and it was around 39. So for the price it isnt bad. Make sure the edges of your door are sealed.
  3. #3
    Ron Ketcham's Avatar
    Join Date
    Mar 2001
    Location
    Keokuk, Iowa
    Posts
    2,877
    Images
    56
    Got the same steel door sort of thing.
    I went to the local lumber yard and bought some 5/8th inch white strofoam cheap panels, white.
    Measured, cut (easy to cut with any knife, etc), fit them so they would insert into the channels of each panel.
    Some liquid nail adhesive on the steel, put them in and they have been there for the third winter.
    Cost, maybe $20 tops.
    Plus the white foam aids in the light of the shop.
    Grumpy
  4. #4
    Senior Moderator
    Brad B.'s Avatar
    Join Date
    Mar 2001
    Location
    St. Louis
    Posts
    4,985
    Images
    5
    I purchased bulk foam panels and cut them to size myself. It made a huge difference in cooling/ heating and noise reduction! Do it!
    2012 VW Touareg, 2007 Porsche Cayman S, 2005 Audi S4, 1996 Porsche Carrera C4S, 1973 BMW 2002tii
  5. #5
    salty's Avatar
    Join Date
    Jul 2004
    Location
    Swift Current Saskatchewan Canada
    Posts
    2,135
    I have a wood door and screwed foam on it. Also did whatever else could be done to make it better. Works well enough up here in cold Canada
    Mark
    deluxedetailing
  6. #6
    Join Date
    Jan 2009
    Location
    Wilkes-Barre, PA
    Posts
    1,069
    I kicked this idea around a little, but was concerned about any added weight to the door. I know foam insulation is not that heavy, but after time, will the added weight (regardless of how slight) take it's toll on the opener?
    Ryan
  7. #7
    Join Date
    Mar 2001
    Location
    Keokuk, Iowa
    Posts
    2,877
    Images
    56
    Not the white styro foam, it's like air. On my single door, doubt that it added 1 lb.
  8. #8
    Join Date
    Dec 2011
    Location
    Suffolk, VA
    Posts
    122
    as in eletric garage opener? Not at all.. the whole door is made from steel and aluminum. 5-10 extra pounds probally isn't even enough of a varience from what some doors weigh anyway.
  9. #9
    Accumulator's Avatar
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    34,399
    Hmm... I might oughta consider that insulation for the overhead doors that are "actually part of the house". Just wish I could do something for the steel roll-up doors on the shop.
  10. #10
    salty's Avatar
    Join Date
    Jul 2004
    Location
    Posts
    2,135
    The foam weighs nothing, as stated. Me having a wooded door helps a great deal. Steel is cold.
    Didn't help that it is -40 F or C (wind chill) the last couple days, and my dad tried to back through it yesterday. Damage was not that bad, but I've never felt my heart drop that bad or a door bend that much and still be half assed usable. $1000's dollars of chemical was in danger and an extractor.
    Mark
    deluxedetailing
  11. #11
    Join Date
    Jul 2007
    Posts
    808
    The insualtion pannels in the kit seem kind of bulky from what I have seen. Did you notice that it added much entra weight to where you had to adjust the tension on the door opener?
    Grumpy
    Now that is a good idea. Do you happen to know what the R rating is on the foam you used? If it is as effective as the insualtion kit, this sounds like a cheaper and better solution
  12. #12
    Join Date
    Mar 2001
    Location
    Keokuk, Iowa
    Posts
    2,877
    Images
    56
    Nope, have no idea of the R rating.
    All I know is that they insulate quite well, used my infared thermometer to measure without one day, was 15F outside, inside of door was 16F.
    After I put up the foam, was 20F outside, inside of door was within 5 degrees of interior temp, which at the time was 61F.
    All I know is that is works, it's inexpensive and a good friend who is a home builder thinks I am now a genius.
    Grumpy
  1. Need a New Garage door- Looking for recommendations
    By YeboGoGo in forum The Man Cave
    Last Post: 02-20-10, 09:16
  2. garage door insulation?
    By evil_c5 in forum The Man Cave
    Last Post: 12-10-04, 03:18
  3. Scratch scratch.. Garage insulation is done…*pic*
    By Redcar GUY in forum The Man Cave
    Last Post: 08-04-04, 04:23
  4. Got Insulation? (Garage)
    Last Post: 07-31-04, 02:37
  5. Garage door insulation....
    By Glenn J in forum The Man Cave
    Last Post: 01-17-02, 08:10
Posting Permissions
  • You may not post replies
  • You may not edit your posts
