Page 1 of 2 12 LastLast
Results 1 to 12 of 15
  1. #1
    Garage Storage Cabinets questions
    Join Date
    Jan 2009
    Location
    Wilkes-Barre, PA
    Posts
    1,069
    I am still in the planning stage of remodeling my garage this spring. After reading up on flooring, and hearing some claims that others have made about racedeck squeaking, I looked into a few different floors, and have narrowed it down to racedeck or swisstrax. I am receiving samples from both next week, but swisstrax customer support is phenomenol, and actually after speaking with them, they agreed to take 1.20 per square foot off to earn my business.
    Anyway, to my questons: Since this is a budget remodel, trying to stay under 4,000.00, (2,000.00) of which is going to flooring, and the rest into cabinets, paint, lighting, and odds and end. I need ALOT of cabinets, and have narowed it down to either Gladiator or Utili-Mate cabinets. Does anyone have either of these and/or knowledge of these for comparison purposes? Any help would be greatly appreciated.
    Ryan
  2. #2
    Re: Garage Storage Cabinets questions
    Join Date
    Jan 2009
    Posts
    83
    Ryan - I have the Ulti-Mate garage cabinets and I really like them. I picked mine up a Sears and have had them for about 3yrs. now. Very sturdy and the shelfs do not bow with the weight that is on them. I get lots of compliments on them as well. Good stuff.
  3. #3
    Join Date
    Jan 2009
    Location
    Wilkes-Barre, PA
    Posts
    1,069
    Rex, how is the finish on them? I dont want the pro series, just the regular series in slate grey. I was concerned about warping from any moisture/humidity in the garage. I found a website where I can get the 8 pc set for 1395.00.
    Ryan
  4. #4
    Greg Nichols's Avatar
    Join Date
    May 2006
    Location
    Logan Utah
    Posts
    1,626
    check with your local cabinet guys, I found they could build to my specs better and cheaper than the generic ones.
    laminate is the best for faces and tops if near moisture. I just got new cabinets less than 6 months ago.
    GREG
    Reflections Detailing of Utah
    "Detailing for the discerning owner"
    "There is nothing more gratifying then when a client shows up and can't describe how their car looks without using profanity" (911 fanatic)
    Meguiars/Ford detailing team SEMA 2010 and 2011
    Ask a pro blog writer for detailed image
    duPont Registry approved detailer
  5. #5
    Join Date
    Jan 2009
    Posts
    83
    I don't have the pro-series, I have the slate gray ones you are refering to. I have had no warping issues at all, they are real thick and sturdy. From time to time I need to wash a vehicle in my garage and they have gotten wet. The only small issue is the handles show tiny rust spots, but its metal, raw metal doesn't like water. A bit of steel wool will clean them quickly. Like I said, they are very 'professional' looking and I get compliments on them all the time. Too bad you are not a bit closer (I'm about 2hrs. from you), you could see them in person before you bought them.
    Most Sear's stores had them on display when I bought them. I ordered online from them and then picked them up at the store to save a lot on shipping.
  6. #6
    Accumulator's Avatar
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    34,402
    Stree5927- What do you plan to use the cabinets for?
    I ended up *not* getting cabinets for my shop at all, they just weren't right for the application. And yeah, I was a bit "Aww..but I really think they'd look cool!" about the decision, but "form follows function" and they weren't what I really needed from a functional viewpoint.
    Ten years later, no regrets. Even though the shop would look nice with 'em. But hey, that's just my situation.
    I do have cabinets on the other, "non-shop", garage; different situation, different set-up so I can see it both ways. Just make sure you're putting your $ into the right stuff before you spend it. Had I put cabinets in the shop I woulda ended up taking them out and wondering what to do with 'em.
    Working within your budget, I'd probably rather spend the money on lighting and other electrical work, or at least I'd prioritize that and see what's left over for cabinetry.
    You mentioned humidity as an issue- what're the plans to control that?
  7. #7
    Join Date
    Jan 2009
    Posts
    83
    Yeah, your're right. For my situation they are working real nice. One thing I do like is that supplies are behind closed doors and I don't have to answer "What's that for?" over and over. Lighting and your electrical setup are more important than having these cabinets. You can make do with other things for a while until you have the $$ for them.
  8. #8
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    34,402
    One thing I do like is that supplies are behind closed doors and I don't have to answer "What's that for?" over and over..
    Yeah, I can see the benefits of having stuff out of sight. That's just not an issue in my situation but I bet it's a biggie for pros and/or people with children who get into things.
  9. #9
    Join Date
    Jan 2009
    Location
    Wilkes-Barre, PA
    Posts
    1,069
    Thanks for all the input. To answer your questions Accumulator...Right now, I just have wire storage shelves. I am looking at this from many different angles. 1.) With new cabinetry, base and wall cabinets, I will be able to have more storage for stuff that is really cramped on my shelves right now, which many times fall off the shelf onto the floor. 2.) Be able to organize things a little bit better. 3.) I want a cleaner look, because right now, it looks like there is no organization and everything just looks cluttered. 3.) Having a dog and spending alot of time outdoors, I am hoping that keeping things in the cabinets will keep them less dusty. 4.) Dust & dirt collection under and behind the cabinets will not be an issue (this goes along with installing a new floor...which by the way, I have decided to go with the swisstrax), and I will be able to just run a vacuum/mop over it to keep it cleaner and a more dust/dirt free environment. 5.) With the cabinets, I am going to install a work bench in with the cabinets, which will give me somewhere to tinker on projects, as I don't have a work area now. Since my house is only 10 years old, I have (2) seperate 20 amp breakers, one for the central vac and one for "whatever". I have enough recepticals in the garage, and even have them in the ceiling. I recently installed (4) 4' T8 light fixtures; probably not the greatest for detailing, but they give off ample light for the amount of detailing that I do, plus just for general purpose work. I may install two others, but that can wait for now. As far as heat, I haven't decided what I am going to do there, but since it is attached, it was 20 degrees here today, and it was 38 in the garage. I have yet to have it dip below freezing; so it's not a huge issue right now. In the summer, I run a de-humidifier in the garage and basement, so that's how I deal with the humidity, although there is always going to be a certain amount of humidity. I also want to invest in the Gladiator track system that is sold at Lowes for storing brooms, shovels, etc on the walls. A very nice (Clean) look and will be very functional. Besides, the walls need to be repainted, so I am going with a two tone paint, white, light grey and charcoal to match the flooring and cabinets that I have picked out. Overall, I am looking at this as a way to increase storage, functionality, while making it look "nicer".
    Ryan
  10. #10
    Join Date
    Sep 2002
    Location
    NE Ohio
    Posts
    34,402
    Street5927- Ah, I can see you've put a lot of good thought into this. Now I can understand why you want the cabinets. And yeah, it oughta be both functional and good-looking
    I gather the cabinets/work bench aren't gonna cut into your floor space too much. Yeah, it'll be good to have a work bench (get a good vice ).
    I was wondering about the humidity in part because of your flooring...wasn't sure it it'd retain water I had to rethink my choice of shop flooring (and have the floor torn up and redone!) after the "the water will flow to your drains!" sales pitch didn't work out in practice.
    Your color scheme sounds sorta like what I had at my previous shop- I had very light gray walls, with a darker gray lower area that hid dirt a little better.
  11. #11
    Join Date
    Jul 2011
    Posts
    1
    You should also think of diposition for water to be well drian... I had a custom storage systems and the water was stuck behind it...
    good luck
    Josée
  12. #12
    Senior Moderator
    Brad B.'s Avatar
    Join Date
    Mar 2001
    Location
    St. Louis
    Posts
    4,986
    Images
    5
    I also did light grey walls and darker grey lower section and floor. Holding up well after several years.
    2012 VW Touareg, 2007 Porsche Cayman S, 2005 Audi S4, 1996 Porsche Carrera C4S, 1973 BMW 2002tii
  1. Detailing Parts Storage, Lockable Cabinets
    By RiCeBrNr in forum Canada
    Last Post: 07-17-07, 01:44
  2. Replies: 5
    Last Post: 05-31-05, 10:39
  3. Garage Cabinets
    By detailbarn in forum The Man Cave
    Last Post: 02-05-04, 11:04
  4. Storage cabinets
    By AndyC in forum The Man Cave
    Last Post: 02-05-04, 03:03
  5. Garage Cabinets
    Last Post: 04-07-03, 06:13
Posting Permissions
  • You may not post replies
  • You may not edit your posts
